Electrical issue?
  #21 (permalink)
Old 13 Nov 2009, 12:22 pm
Default Re: Electrical issue?
Great, I hope it's something as simple as the battery!
  #22 (permalink)
Old 13 Nov 2009, 10:18 pm
vtmdsm27's Avatar
I had a Mopar battery in my 08 vert that wouldn't stop corroding. A mechanic friend checked it and said it was the battery post itself, inside the battery. I was under 36K, so took it to dealer who said not only was the Mopar battery bad (even though I could still start the car), but the positive cable had practically disentegrated. Told me it was a common problem, and that the pos cable is a special build and expensive. Warranty covered, but they put another Mopar in. The CCA on that Mopar is weak, but I couldn't beat the price.
2008 Turbo Vert
"The trouble with quotes on the Internet is that you can never know if they are genuine." -- Ben Franklin, 1706-1790
  #23 (permalink)
Old 14 Nov 2009, 12:32 am
This has happened a lot on '06 PTs. My '06 GT did this then it would die when you stopped or slowed for a light.
The dealer claimed that I was the only one with the problem, Not true, there are several complaints filed with the feds.
I mailed the complaint card from the back of the owners manual to Chrysler.
Finally got it fixed. They replaced the computer and some ignition parts. Not sure which. The dealer has sold out.
Richard -
'09 Dream Cruiser
  #24 (permalink)
Old 19 Nov 2009, 03:46 pm
My issue re-appeared today as I parked the vehicle and was about the shut it off.
So, my defective battery wasn't the answer. I also don;t think its the ignition switch because it doesn't affect the radio or anything else that uses/runs off the ignition switch.
Richard -are you able to provide exactly which parts the dealer replaced? What do you mean the "dealer has sold out"?
2006 PT Cruiser MTX Base
Magnesium Pearl
100,000km/60,000mi
  #25 (permalink)
Old 19 Nov 2009, 08:55 pm
Okay so i have a 2007 pt cruiser and with in the last couple of weeks my instrument panel will go crazy. my mph wont register neither will my temp or rpms. the oil battery and every other light will come off, but when it does this its intermittent. it will do it for a few minutes to a few second before it either stops and goes back to normal or the gauges just stop working all together. sometime this problem is fixed or aggrivated by hitting a bump or something. any info will be helpful
  #26 (permalink)
Old 20 Nov 2009, 10:53 pm
Yes the dealer sold out or traded dealerships.
The work order did not show what was replaced. They told that the Chrysler engineers said that that had to be the computer or the ignition module. So they replaced both. I will try and see if the new dealer has the info.
Richard -
'09 Dream Cruiser
  #27 (permalink)
Old 21 Nov 2009, 08:50 am
Thanks a lot - that would be great. My PT is out of warranty, so if I have to buy either of those modules its gonna be big money!
Magnesium Pearl
100,000km/60,000mi
  #28 (permalink)
Old 14 Dec 2009, 01:26 pm
Sorry to be so long getting back on this. But, i have been sick.
Did find the part numbers. It was the PCM and the Ignition Switch Assy
FP-Number 5033441-AD Module PO 8035029
FP-Number 4685719-AD Switch IG 8050082
Richard -
'09 Dream Cruiser
  #29 (permalink)
Old 25 Feb 2010, 09:07 am
Well, with over 1000 views on the topic, others must be having the same problem!
Any ideas? I haven't replaced anything yet because the vehicle will go weeks without any issues and then it will act up twice in a day. I notice it a lot when braking, but it does happen when I'm simply driving a consistent speed.
I don't want to spend $600.00 on a new computer to find out it wasn't the problem.
Could it be the multi-function switch?
Magnesium Pearl
100,000km/60,000mi
  #30 (permalink)
Old 25 Feb 2010, 12:56 pm
I had truck do that it turned out to be a relay. not sure witch one.
Electrical Gremlins SantaGuy General PT Cruiser Discussions 10 24 Sep 2009 05:01 am
need electrical help thundercat2 Tech & Performance Forum 0 27 Sep 2008 08:02 am
Electrical problems need help bad! SilverPT Tech & Performance Forum 2 14 Sep 2008 09:54 pm
Electrical Nightmare igloo0001 Tech & Performance Forum 10 08 Mar 2008 10:00 pm
Electrical problem ARAMIS327 PT Cruiser Convertible Forum 1 20 Nov 2007 07:47 pm
