I did a search and the results were only mentioning swapping to disc rear brakes. My passenger rear drum shoes are rubbing against the backing plate. I have replaced the drum and it went away. 10 days later i hear it creeping back. The shoes are about 9 monthes old and in great condition. as i come to a stop i hear it so the noise is a slight rubbing, right as I come to a stop. Not the entire time I am braking.
I can see where the rubbing is taking place but not sure what I can do to alleviate the problem. Little bit of grease?? any help would be greaaaat. TIA
2004 PT Cruiser-Limited |
Go to your nearest auto store (NAPA has it for $3) and pick up a tube of high temperature grease. Put it on the edges of the shoes or smear some on the baking plate.
ok thanks.
see if that will do it.
Applying grease to brake parts!?
Better use it sparingly and away from the shoe braking surfaces. ![]() This raises more questions in my mind......... Is the rubbing sound as it rolls round and round? Or as the brakes go in and out with pressure? Did you have the drums turned or replaced 9 months ago when it got new brakes? Was that a DYI job or pro done? When you replaced the drum, did you also replace the shoes? Was this a DYI job or pro done? At any rate - brakes are too important to be half-way done. I suggest taking it to a qualified shop.
I'm not saying to slop it on all over the place but a little dab of high temp brake grease on the contact points of where it's rubbing.
For some more ideas: Eliminating Disc Brake Noise (bottom of the article talks about drums)
Got the above PM from the OP....... Does not sound like grease will help with a rotating rub...... Like I said more questions needed to be asked..... More like fixing whatever is bent needs to happen.........
![]() Crewzin offered advice, a reccomendation NOT a direct order to slap grease all over the place. Advice has been taken. thanks
Cry me a river........Now go fix your bent axle and grease something else......
| Rear Drum Brake Swap? | mopar1cjh | Turbo Wheels/Suspension/Handling | 1 | 06 Aug 2009 09:15 pm |
| Drum brake replacement Parking brake cable | Dorkygrin | General PT Cruiser Discussions | 2 | 28 Mar 2009 07:53 pm |
| Brake Drum Removal | seafox | General PT Cruiser Discussions | 7 | 18 Dec 2008 03:38 am |
| Drum Brake Cover | Herschel | Turbo Wheels/Suspension/Handling | 3 | 11 Jul 2005 08:05 pm |
| Brake Drum and Caliper Paint | technobear | Exterior Accessories Forum | 6 | 05 Jul 2004 10:01 pm |
