Stuck in the mud
Old 28 Oct 2009, 11:18 am
Default Stuck in the mud
My 2006 PT is stuck in the mud. My only vantage point is to pull it backwards. Where on the car would I connect the towing straps?
I couldn't find anything in the booklet or the search on this site.
Thanks in advance,
Andre
Old 28 Oct 2009, 12:25 pm
AlTheKiller's Avatar
Default Re: Stuck in the mud
ill go take a look but my guess would probably be from the rear axle
Edit: yup thats where id do it. make sure its with a recovery strap and not a tow strap. the difference is the metal hook. you DO NOT want to use that for recovery. i know the PT is light but that hook can snap off and go through your window or worse into your head. ive seen it happen more times than i care to remember. also if the vehicle that is pulling you out has a tow hitch DO NOT use the tow ball. same thing can happen.
Old 28 Oct 2009, 01:31 pm
That's exactly where I ended up attaching it. The axle worked perfect.
I did use the straps with the hook. However, I wrapped it around and attached it to itself. With my wife in the car backing up while I pulled, it went very easily. I used 4 - 2,800lb straps. Overkill? Sure, but I wanted to avoid the possibility of the straps breaking by distributing the weight out.
Thanks
Andre
Old 28 Oct 2009, 06:16 pm
thats good you did it in a safe manner. not everyone will have recovery straps handy and i wouldnt imagine a PT Cruiser getting so stuck it would break a strap but you never know. glad to hear you got it out
Old 28 Oct 2009, 09:17 pm
Chromenut's Avatar
Glad to hear you got it out safely without damaging it! lol
...if I only had a brain...
I would need my own forum just to list my mods!!!
Remember, a PT Cruiser is not just a car, it's a way of life!
LAUS DEO SEMPER
Old 28 Oct 2009, 09:27 pm
Me too. The rains just started again (central Texas) and will continue for the next couple of days. Who knows when the ground would have been hard enough again to get it out. LOL.
Old 28 Oct 2009, 10:12 pm
central texas huh? im in austin (well right at the border of austin and cedar park) if you are by me and you ever need a pull just let me know
Old 29 Oct 2009, 03:32 pm
Cool! I appreciate that. I'm on the other side of Austin out towards Bastrop
Andre
Old 29 Oct 2009, 08:03 pm
good stuff. ive got a fleet of people who can always help out so dont hesitate to ask
Old 29 Oct 2009, 10:11 pm
Will do. Thanks again.
Andre
Tags
mud, stuck in mud, towing
stuck thermostat? supgrrl General Turbo Discussions 4 01 Oct 2009 07:41 pm
stuck valve coco1476 Tech & Performance Forum 7 23 Sep 2008 12:34 am
What's the worst MOD you got stuck with? stirfry General PT Cruiser Discussions 10 13 May 2004 09:20 pm
stuck throttle Punch General Turbo Discussions 9 02 Feb 2004 06:56 pm
Key stuck in ignition Tabitha Tech & Performance Forum 7 16 Sep 2003 01:03 am
