stalling
Old 11 Dec 2009, 12:22 pm
Default stalling
my wife has an 03 pt cruiser non turbo with a 5 speed.It has 79000 miles.the car stalls when coming to a stop or driving at low speeds.I have replaced the spark plugs recently and in the past the cam sensor several times.no trouble codes come up.I cant find any vaccume leaks.It cleared up after checking for trouble codes,but a couple days later began to act up again.?????
Old 11 Dec 2009, 01:11 pm
Default Re: stalling
Have you changed the spark plug wires? If they are stock wires (came from the factory) they are poorly made and should be changed at the same time as the plugs. If they have been changed, you might have a problem with the IAC (Idle Air Controller). Helps maintain a steady idle especially when the air-conditioning is running. It's located on the back and attached to the throttle body.
Old 11 Dec 2009, 03:39 pm
thanx for the reply.no I havnt changed the wires yet,Ill try that.Im also going to check the I A C . Do I have to replace it or can I just clean it?
Old 11 Dec 2009, 03:45 pm
haven't done it myself but was told it can be cleaned.
'04 PT GT stalling, out of the blue... cbohlson General PT Cruiser Discussions 17 04 Jul 2011 10:06 am
Stalling but not Dying COMTNBKR Tech & Performance Forum 4 16 Oct 2009 11:02 am
Stalling sifu_scott Tech & Performance Forum 2 10 Dec 2007 05:35 pm
Stalling while braking.... CHROMEDCRUISER Tech & Performance Forum 1 15 Feb 2005 04:55 pm
engine stalling onyx pt General Turbo Discussions 11 10 Sep 2003 01:18 am
