Work I Did Last 3 weeks
  #11 (permalink)
Old 17 Dec 2009, 09:49 am
chris15's Avatar
Default Re: Work I Did Last 3 weeks
Just as a word of caution: I ordered that exact grille off of Ebay, from the exact same seller-- horrible product. I may have wound up with a bad egg, but the fitment was WAY, WAY off. The top uses two brackets that bolt into two of the original mounting points of the OEM grille, however, the bottom of the upper grille has two brackets that are welded in place and are supposed to fit over two other holes in which you use the original screws to secure it. On mine, the brackets on the bottom were extremely out of place. I had pictures that I had to take to send to the seller to explain the problem, but I couldn't believe someone would produce something as bad as that. They obviously don't test fit what they produce.
As a side note, the grille did look very nice, as I was able to secure the top of it. I honestly wish I could have made the bottom brackets work, but I don't have the equipment to weld that type of metal. Also, if you have a lighter colored PT (white, bright silver, etc.) be prepared to paint the areas behind the grille, as they will show through. The areas on top and bottom of the billet spears (?) ARE black, and the fronts have a highly polished finish.
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
New Clutch went bad after 2 weeks??? Ctown Tech & Performance Forum 7 25 Sep 2009 03:40 pm
383 PTs have REGISTERED!! 2 weeks to go PT_Sean Canada PT Forum 1 01 Jun 2005 09:01 pm
T-3 weeks and counting airevac19 General PT Cruiser Discussions 6 15 Dec 2004 06:12 pm
almost 2 weeks later still no car!! bobs turbo pt General Turbo Discussions 2 25 Aug 2003 06:06 pm
After 8 weeks .... RetroPT General PT Cruiser Discussions 8 14 Apr 2003 06:39 pm
