Hi I recently started to notice a red liquid on the floor of m garage. After I noticed it, it then stopped. I checked the coolant levels and the reserviour was almost empty and the radiator was full still. It stopped for like a week. Then it started again. I finally checked it again and both were empty this time. So I filled them up. I know I have a leak somewhere around the battery area. Everything in the battery area has pink dots in it. So it has to be spraying out somewhere but I cant find where. The holder for the batttery also has a small amount of coolant sitting in it. I will post pictures showing the problem.
the best way to find coolant leaks like this is to get a coolant system pressure tester. It is a little hand pump that goes on in place of the radiator cap and pressurizes the system with the engine cold.
If I had to guess I would suspect hoses and clamps since I can tell by the markings that they are the factory originals. |
yes everything is factory in the engine. I havent had to replace anything. Ill do the pressure check though and see what I can find.
If not hoses or clamps, check the thermostat gasket.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
BARS Leak told me it it standard practice for all the auto manufacturers to use their product from day one-- worth a try for this small leak( mine was on edge of radiator) these radiators are alluminum & plastic- all leak eventually a little-this will seal it( just gain use it in 1/3rds. MJB
| Tags |
| broke, coolant, leaks, problem |
| Coolant Leak - Timing Belt | hdave | Tech & Performance Forum | 2 | 16 Dec 2009 05:58 pm |
| Coolant Leak | rcalzadilla | Tech & Performance Forum | 29 | 25 Oct 2009 01:29 pm |
| coolant leak from the radiator drain | geronimo | Tech & Performance Forum | 1 | 19 Jul 2009 02:55 pm |
| coolant leak | RaceWilson | Tech & Performance Forum | 7 | 14 Sep 2008 09:49 am |
