Doors wont open! HELP
Old 30 Dec 2009, 03:51 am
yteka99's Avatar
Send a message via AIM to yteka99
Default Doors wont open! HELP
So i got a carwash today and it was pretty cold. Probably about 20* F. I went snowboarding for about 5 hours and when i got to my car the key wouldn't unlock the door. So i tried the other side. Same thing. It would turn but the knob wouldn't pop up. So i had to go in through the trunk and unlock the backdoors. I tried to pull up on the knobs but they wont go! The electric unlock doesnt work either. It does the normal beeps and you can hear it move but than the knobs only go up about 1/4" . I don't know how to get my doors open. I heard they might just need to thaw out, put wd40 in the locks and hope it works. I put wd40 in there but i was also told that lock de-icer srews up your locks by drying them out. Any help is MORE than appreciated. Thanks
rockin grampa's pt
Old 30 Dec 2009, 06:13 am
Default Re: Doors wont open! HELP
Lucky the rear hatch opened!
I was thinking maybe the rocker switch on the door got wet and shorted in lock position, but that would lock the hatch, too.
Sure sounds like the locks or that water got down past the window seals into the door and froze up the lock mechanism...
Blast a hairdryer on the locks and see...
Old 30 Dec 2009, 02:35 pm
yteka99's Avatar
My car only has power locks on the front doors. The hatch is only with the key. I'm taking it to my uncles to kep in his heated garage for a few hours ill let you know how it goes.
rockin grampa's pt
Old 30 Dec 2009, 02:57 pm
yteka99's Avatar
I went outside and the doors just suddenly work! I'm not sure if the wd40 helped or not but its still only like 33* F.
rockin grampa's pt
Old 30 Dec 2009, 04:46 pm
Rocker switch to lock the doors on door? Maybe switch got wet and shorted in "lock".
WD-40 sure can't hurt. It repels water.
AC Wont come on Sharkstooth Tech & Performance Forum 18 08 Aug 2009 10:18 pm
car wont turn on. fvillota General PT Cruiser Discussions 12 06 Apr 2009 10:56 pm
Wont start now? morrisbeer General PT Cruiser Discussions 2 21 Feb 2009 10:14 pm
07 TE PT wont start PLEASE HELP!!!!! Norma Tech & Performance Forum 10 08 Dec 2008 08:58 pm
You wont' believe this CREWZIN Non-PT Discussions 7 19 Jul 2005 02:40 pm
