Looking for L.E.D. lighting suggestions...
Old 31 Dec 2009, 02:46 pm
THS_Cruiser03's Avatar
Lightbulb Looking for L.E.D. lighting suggestions...
Hi Mopar Brethren!
I was wondering of some if you have some ideas about LED lights to replace stock PT bulbs...
I want to enhance the lighting on my PT to match the color of my Xenon (8k color) headlights. So I'm looking for LED based replacement bulbs for....
- Rear liscence plate bulb suggestions
- Reverse lights
- Dome light
What do you guys like out there?
Outfit/Rocketman: What do you guys have?
I know you guys have some ideas.
Thanks!
Tom
Base '03, Light Almond Pearl Metallic - Modified 2.4 na w/ported head, 10.4:1 compression ratio & Crane #10 camshafts - 4 speed - Energy Poly bushings - Napa ceramic pads & Ultra premium rotors - Rotora Stainless brake lines - Extreme Acc. Xenon HID 8k low & 6k high
Dark taupe & Ivory Interior, Factory CD w/Sirius Stratus 4, Power Acoustik 840w 4ch, Boss 200w 2ch w 10" bandpass sub, 2 sets Phoniex Gold Matched comp. speakers
Rolling stock: 16" SE A7w 225/50/16 Kuhmo Ecsta AST - One of the nicest Light Almond PT's you'll find
Old 18 Jan 2010, 11:46 am
Question Re: Looking for L.E.D. lighting suggestions...
I'm getting crickets on this....
No ideas or nobody saw the post...?
Suggestions...
Old 18 Jan 2010, 05:18 pm
ROCKETMAN8060's Avatar
Default Re: Looking for L.E.D. lighting suggestions...
I did all my lights LED's including the fog lights! I got some pictures in my profile so you can see them.
ROCKETMAN8060
Old 20 Jan 2010, 07:59 am
Our PT has been in the family less than a week, replacing a Neon coupe. I can offer you a few ideas from the extensive use of LEDs in our Neon, and you figure out which ones you'd like to apply to your PT.
Our Neon had LED center brake light, trunk, dome, glove box, instrument cluster, and rear license. I used a lot of LED strips like the one shown below---cheap and plentiful on eBay.
Joseph -- La Crosse, Wisc. USA -- Also active on Neons.org, Recent Convert to PT Cruiser brought on by a distracted [other] driver who totaled my car.
Old 20 Jan 2010, 04:31 pm
SUPER BRIGHT LEDS - LED Lights & Accessories
I'm thinking about ordering from there........I'm just having trouble cross referencing the bulb numbers, etc...
Old 20 Jan 2010, 08:39 pm
Just keep in mind that LEDs draw a lot less current and produce a lot less light output (lumens) when you compare an incandescent and LED bulb of the same physical size. To get enough light, you need an LED strip or array that is larger than the incandescent you are replacing.
For example: The stock glove-box light in a Dodge Neon is a 168/194 incandescent. The light is a point source and poorly distributed across the glove box. In our Neons we replaced that with a flexible white (meaning blue-white) LED strip, IIRC 24 LEDs in a strip about 10" long, attached with double-sided foam tape to the "roof" of the glove compartment. The result is plenty of light, well distributed, even for map reading. The trick was to install a 168-style wedge base on the wires to the LED strip, so it would plug into the stock fixture.
Another example is in the trunk of the Neon, we used a white LED strip containing IIRC 48 LEDs.
Old 21 Jan 2010, 01:41 pm
Cool Re: Looking for L.E.D. lighting suggestions...
You can also find several items of LED's 194 here!!!
194 led, buy and sell Parts Accessories on eBay Motors
ROCKETMAN8060
01 radio lighting comes and goes edsidders Sound and Security Forum 21 09 Nov 2009 06:02 pm
HID Lighting Kit Install jayguliano Exterior & Interior Styling 5 08 Oct 2009 04:32 am
Grille Lighting PTmodrod Exterior Accessories Forum 24 23 May 2008 07:39 am
Under-Car Lighting PTKollar Exterior & Interior Styling 4 21 Jul 2005 09:54 am
Under-Lighting tsatrasen Exterior Accessories Forum 0 17 Jun 2002 07:21 pm
