Won't turn over when warmed up
Old 31 Jan 2010, 08:44 pm
Default Won't turn over when warmed up
My daughter's '03 GT.
Starts fine when cold.
Recent new battery.
When you stop for gas, etc, and go to restart, it just clicks, but a jump works.
I took off, cleaned, and tightened the battery clamps.
Any ideas?
Old 31 Jan 2010, 08:56 pm
Default Re: Won't turn over when warmed up
Don,
Was surprised to see you with a problem. Maybe it could be the starter solenoid going bad. Don't know how to test it. The clicking does sound like the battery but you said it's new. I'd pop over to Auto Zone or another auto store that will test the starter system anyway just to be sure.
Old 31 Jan 2010, 09:05 pm
Thanks, Crewzin.
Weird that it starts when cold - when battery would be weakest - and that a jump works.
Has me baffled.
Old 31 Jan 2010, 09:11 pm
Don,
Not our PT but something to read about vapor lock.
Subaru Legacy Forum - won't start when warm - CarGurus
More to read.....
http://www.fixya.com/cars/t593597-9000_start
Old 31 Jan 2010, 09:31 pm
Read those - can't be vapor lock, and can't be ignition lockout, since a jump works fine. If it were battery, then it wouldn't work on cold start...
I'm really puzzled.
Old 31 Jan 2010, 09:36 pm
Sorry Don, out of ideas but have the starting system checked out just for peace of mind.
Old 06 Feb 2010, 02:45 pm
Matt42's Avatar
Is the starter cable corroded at the starter connection? Grasping at straws here.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 06 Feb 2010, 08:55 pm
Make sure that you have 12 volts at the small connection of the starter when the key is put in the run position. If you do you know all of the cars starting system wiring is good. I'm guessing it will be. Next try moving the thick battery cables to ground and the starter to see if either is coroded and getting a bad connection. If moving the cables helps, there is your culprit.
Next, tap on the starter a bit to see if it moves the solenoid in the starter. If that helps then it is probably the starter assembly.
I'd bet either the cables or the starter itself. The jumping just gives extra power to overcome the extra resistance of worn cables or the starter.
Let us know what it turns out to be.
Old 06 Feb 2010, 08:56 pm
Sorry, 12 volts with the key in the start position
Old 09 Feb 2010, 08:34 am
Dino's Avatar
Recent new battery.
Any ideas?
If the problem started with the new battery than you might have gotten a bad one. If it's still under warranty than return it and get a better one. I was going crazy with starting problems on an old Toyota and never thought it was the battery because it was new and finally I got desperate and changed it with a better one, that top of the line walmart sells for like a 100 bucks and the problem was gone.
But I also remember with an old VW Rabbit having the same problem and I had to change the starter. Good luck
Will not turn over warnockdonald Tech & Performance Forum 12 31 Dec 2012 03:12 pm
dome light doens't turn off till i turn on the car... realized Interior Accessories Forum 3 15 Jul 2009 06:44 pm
Turn Will not turn PT 2002 WanttoPimpthePT Tech & Performance Forum 19 09 Jul 2009 12:43 am
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
key will not turn Beam General PT Cruiser Discussions 25 24 Dec 2003 06:38 pm
