2004 PT Cruiser Wont Start
Old 03 Feb 2010, 06:18 pm
Default 2004 PT Cruiser Wont Start
I have a 2004 PT Cruiser. After a long drive of about 90 miles I stopped the car for about 30 minutes. When I started it up again it ran rough and the engine light came on. Then the engine light started flashing. I was not in a place where I could leave the car to wait for a tow, so I put it in gear to move it a few hundred yards and the transmission would barely engage - I had to rev the engine pretty high to get the car to move. I checked the transmission fluids and oil, they are both OK. I tried to start the car just before it was towed and the nothing happened, the engine did not even turn over. There is plenty of jucie for all of the electrical items (radio, lights, etc) seems like this may be a computer problem. Can anyone shed any light? Thanks.
Old 03 Feb 2010, 07:42 pm
Default Re: 2004 PT Cruiser Wont Start
Hi Brian, you don't mention how many miles you have on the PT. Is it over or close to 100,000? It may be the timing belt, the tranny may have went bust, it happened to me in our 2002, only I could restart the engine, but had to let it sit for a few minutes to get the PT to move a little way.
Old 03 Feb 2010, 07:54 pm
Thanks for the info. My PT has 139K and we had the timing belt replaced along with the water pump at 115K. If it was the transmission the engine should still start, but mine does not. It's unliky the alternator since a bad alternator would drain the battery and there is plenty of juice in the battery. The way the engine and transmission behaved along with the fact the turning the key does nothing except provide electricity for the radio , makes me think it is electrical and/or the engine computer. Thanks again for your reply.
Old 03 Feb 2010, 07:56 pm
So, it's in a shop now? Sounds like a sensor went - crank or cam is my bet.
If they're shot, won't start.
Let us know what it is, please.
Old 04 Feb 2010, 01:14 pm
Quick update. The repair shop called to say that my car is in lock down mode and the computer is preventing the car from starting. This model has a chip in the key to prevent someone trying to start the car with a key that does not have the encoded chip. It appears that the engine computer needs to be reset or replaced. I'll post more when I know more. Thanks.
Old 04 Feb 2010, 08:25 pm
Thanks for update.
Hope it's not expensive.
Please post back with the cure.
Old 05 Feb 2010, 03:04 pm
Most current update is that it appears these is a short in the electrical connections from the ignition.
Old 08 Feb 2010, 07:57 pm
Hopefully this is the final word. As I thought it is the engine computer that is shot. The whole fix is going to be $1,000, most labor costs.
Old 08 Feb 2010, 08:52 pm
How many miles? There's an emissions warranty I think for 50,000 miles - Some have engine computer replaced for free....
Old 09 Feb 2010, 07:12 am
We are way past that, we're at 139K. Thanks for the thought though!
02 wont start Sfos Tech & Performance Forum 15 10 Jan 2014 05:46 pm
02 pt wont start J_GEISLER Tech & Performance Forum 3 19 Jun 2010 10:39 pm
Wont start now? morrisbeer General PT Cruiser Discussions 2 21 Feb 2009 10:14 pm
07 TE PT wont start PLEASE HELP!!!!! Norma Tech & Performance Forum 10 08 Dec 2008 08:58 pm
01 PT cruiser wont start.. EvilWRX General PT Cruiser Discussions 1 12 Feb 2007 02:35 pm
