Air Cleaner Housing "Clip" Needed
Old 13 Feb 2010, 03:02 pm
Default Air Cleaner Housing "Clip" Needed
Can anyone advise where I can get one these "Metal Clips" that hold down the Right Side of the Air Cleaner Housing? One of the clips flew off while changing the Battery. Model: 2002 PT Cruiser Touring
Old 14 Feb 2010, 12:42 pm
Matt42's Avatar
Default Re: Air Cleaner Housing "Clip" Needed
First, try probing around with an extending "pencil" magnet. The clip went somewhere.
Second, try a wrecking yard. I bet a Neon would use the same clip.
Third. the dealer.
Fourth, use a heavy duty binder clip, from a stationery store, or a small C clamp, in the interim.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 14 Feb 2010, 06:17 pm
Thumbs up Re: Air Cleaner Housing "Clip" Needed
Thanks Matt! Great suggestions.
Old 03 May 2011, 06:59 pm
Using the picture posted here can anyone tell me what is the hose for next to the arrow is for? In my 2004 PT Cruiser 2.4L Turbo is missing it and want to know what its for? While im on the subject would this cause the check light engine to go off? Im getting error code the one that has the describtion "vacuum leak around the No#4 cylinder" so i want to know if thats causing it. Im troubleshooting
Old 03 May 2011, 08:25 pm
The hose, along with the air box, is different on the '06 and up PT's, but the hoses function is the same. It's the "make-up air hose", comes off the crank case and is a federal regulation to prevent emission of oil fumes into the atmosphere. The hose takes crank case over-pressure and runs it to your air box into a sponge filter. If you don't have one, you must be putting oil on your engine somewhere. If you look at mine, it's got that hose connection sealed off at the air box, because I run the crank case to an external breather.
Somewhere here on the forums I posted a how-to on this, might want to search it out. Pic below shows the breather I use, clean it just like a K&N filter, using the same cleaner and oil for it.
Old 07 May 2011, 08:21 am
themadgreek187's Avatar
i drilled a small hole and zip tied my old air box when my clip broke on my 01. last yr i removed it for a air intake. much better now!
Old 07 May 2011, 12:25 pm
my 07 was badly abused when i bought it. when i did the once over i opened up the air filter case
first it was glued shut, even worse with wood glue. Second, they took a fram filter that was much too big and cut it then shoved it in to fit. the little clips were broken so i just took it to the local chrysler dealership, i was ssoooo angry i couldnt even deal with it myself.
2002 Pearl Almond Limited Pt "Custom Route 66 " Edition rt66pt Classifieds: For Sale/Trade 59 04 Mar 2013 12:49 am
17" GT Chrome caps needed HemiShelby Classifieds: Want To Buy 0 15 Nov 2009 09:21 pm
