engine problems
Old 16 Feb 2010, 05:35 pm
Default engine problems
I have a 01 pt crusier limited edition that i had an oil change done and afterwards i noticed a knocking noise. I brought it to the dealer and they told me i needed a new head gasket and spark plug seats have 92k on the engine so told them to do it. picked the car up on friday and it was still making a knocking noise but not as bad. car sat on the weekend. on monday drove 15 miles to work. on my way home about 6 blocks away from work the engine stalled no loud clank just stoped running and would not start up again. so i had it towed back to the dealer and they told me the #1 pistion smacked the bottom of the sparkplug and shatterd it. they said i need a new engine. what could cause that. could the dealer done something wrong. thank you
Old 16 Feb 2010, 06:01 pm
Default Re: engine problems
Only way piston can hit the top of the head is if connecting rod broke.
Did they mention timing belt? At 92,000, yo were getiing near, but that cannot cause piston to hit spark plug.
If a connecting rod goes, you may need a new engine...
Old 16 Feb 2010, 11:09 pm
Dino's Avatar
Before you pay dealer price or walk away from your car, check out some engines on ebay. I saw one for 1800 bucks the other day while searching for stuff. It's weird it all happened after your oil change that you heard the noise. Did you notice you were losing antifreeze or oil? Did you have white smoke coming out your exhaust? I'm surprised when the changed your oil they didn't notice the head gasket issue.
Engine problems rich228 Tech & Performance Forum 8 18 Feb 2010 10:17 pm
Need some advice-Problems with my replacement engine Abgmauldin Tech & Performance Forum 11 16 Feb 2009 09:14 pm
Engine Mount Problems chris1916 Tech & Performance Forum 1 15 Jan 2009 03:19 pm
Engine Replacement problems LatinPhilo General PT Cruiser Discussions 7 28 Oct 2008 11:12 am
the engine light - but seems no problems Victoria Tech & Performance Forum 5 25 Feb 2005 10:46 am
