2005 turn signal problem
Old 17 Feb 2010, 05:54 pm
Default 2005 turn signal problem
flashers work front and back this car has no fog lights but no turn signals front or back is it the switch?
thanks for your help
Old 17 Feb 2010, 08:49 pm
Default Re: 2005 turn signal problem
Sounds like the Multifunction switch.
BTW: Welcome to the Forum.
Old 18 Feb 2010, 07:51 am
but i replaced it already........;(
Old 18 Feb 2010, 08:39 am
Do the headlamps, parking lamps (same as turn signal lamps) work correctly?
Old 18 Feb 2010, 11:50 am
yes lights work fine
Old 18 Feb 2010, 12:33 pm
Well, I'm no mechanic but if all the lights work, and the flasher works, about the only thing left is the stalk (multifunction switch) itself but you said you just replaced it. Was it new and was it for a PT without fog lights?
Old 18 Feb 2010, 05:13 pm
found my problem relay switch was bad..........on some model there are two relay switches........one for turn signal and one for flashers
Old 18 Feb 2010, 05:59 pm
Glad you found it.
Rear turn signal problem leroy420 General PT Cruiser Discussions 5 18 Feb 2009 09:43 pm
Turn Signal jmack General PT Cruiser Discussions 5 12 Apr 2005 11:57 am
Turn Signal Fuse Problem Indynick General PT Cruiser Discussions 1 04 Jul 2004 07:33 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
Turn signal gonzomania Exterior Accessories Forum 12 30 Mar 2004 08:53 am
