Whining noise when turning
Old 20 Feb 2010, 12:50 am
Default Whining noise when turning
Hello Guys,
I have an 06 PT Cruiser bought about two months ago. Lately, I notice that every time I make a left/right turn on an intersection and at the point where I'm steering back, I can hear a whining noise for a maybe 2 seconds and it will go away.
Appreciate any idea.
Thanks
Old 20 Feb 2010, 09:41 am
Default Re: Whining noise when turning
Almost certainly your power steering pump. First step is check fluid level and top up with ATF + 4 (Yes, Auto trans fluid!).
It is not unusual for some "groans" when it's cold.
Old 27 Feb 2010, 11:46 pm
heY man, I followed your suggestion by topping up the power steering fluid and I have never heard of the noise since then! thanks.
I only added a small amount of fluid though. Is the PT's power steering that sensitive???
Old 28 Feb 2010, 01:18 am
Apparently....
Glad it was a cheap cure.
Old 01 Mar 2010, 12:13 pm
Is the ATF-4 for the 2001 PTs also? They initially had a different power steering fluid, so can you add ATF-4 (mix it) or do you need to get what it came from the factory with?
whining noise coming from car? feefeethaflee Tech & Performance Forum 14 14 Feb 2010 10:50 pm
Noise when turning. diamonds Wheels, Tires, Suspension 3 16 Apr 2009 02:09 pm
Creaking noise when turning wheel kappa_kruiser Wheels, Tires, Suspension 3 22 Jul 2008 06:14 am
whining noise when acceleration??? ruzz1 Tech & Performance Forum 9 09 Nov 2007 07:46 pm
Slight whining while turning the steering wheel alceryes General PT Cruiser Discussions 4 02 Apr 2004 10:19 pm
