Rear Child Locks
Old 21 Feb 2010, 11:04 am
Default Rear Child Locks
Hi, I am new to the forum and have just bought my first PT. I am having problems with rear doors opening from inside. I have tried moving the child locks switch downwards but it hardly seems to move and makes no difference. Doors open fine from outside - seems wierd as it is the same on both rear doors. Any help would be most appreciated.
Duncz
Old 21 Feb 2010, 12:00 pm
Default Re: Rear Child Locks
Welcome to the forums.
You are on the right path - lever on side of door when you open them - maybe spray some WD-40 in there?+
Old 28 Feb 2010, 10:25 am
Thanks. I tried that and it made no difference at all. Seems strange that both rear doors are having the same problem. Is there something else I should be doing?
Thanks
Old 28 Feb 2010, 10:49 am
Looks like you'll have to get inside the door to see what isn't working. Just tried mine and the lever moves about 1/2 inch, almost the whole length of the oval slit and locks the doors from the inside just fine. If your switches are just barely moving then somethings wrong inside. I do agree that both rear doors having the same problem is weird. Do you have the white sticker next to the lever showing you how it works?
Old 28 Feb 2010, 12:32 pm
Thanks for the quick reply. I know it seems strange being both doors but I will have a look inside this week and let you know what I find
Dunc
Tags
child locks, door locks, rear door locks
Child convertible car seats that fit in a 2006 PT lsfcdf General PT Cruiser Discussions 0 04 May 2009 11:42 am
Child Car seat - LATCH GolowDrew General PT Cruiser Discussions 8 19 Jan 2008 10:47 am
Door locks and Rear window Switch opus General PT Cruiser Discussions 2 18 Jan 2008 05:16 pm
Erratic Door Locks/Airbag/Rear Hatch trikosuave General PT Cruiser Discussions 1 15 Apr 2007 11:23 am
Still the red-headed step child dtbrks Stage Turbo Kits 6 10 Aug 2004 08:59 pm
