Front crank seal oil leak
  #11 (permalink)
Old 25 Nov 2012, 03:27 am
Default Re: Front crank seal oil leak
The original poster hasn't been back to the forum since February 2010 so don't look for an answer from him but if your right about only being out of warranty for 2 months, I think you should talk to the dealer and explain your situation.
Did you buy the car from the dealer you might be talking to? Have you been using that dealer for service? Either of those two things might be of help rather than walking into a dealer you've never dealt with before. It would be like coming here to the forum with your first post and just throwing a question out without introducing yourself.
Tags
crankshaft, front, leak, oil, seal
Crank Shaft Russellhold Tech & Performance Forum 5 23 Feb 2010 07:13 pm
02 pt died and won't crank over ronwins3 Tech & Performance Forum 16 23 Dec 2009 06:25 am
Bell crank bf4cm28 Wheels, Tires, Suspension 3 22 Mar 2009 05:07 pm
Crank Scraper LAF Turbo Performance 0 18 Jan 2004 06:29 pm
Cold Crank, 2nd Try. zzzhuh Turbo Performance 10 11 Jun 2003 10:45 am
