Problems with a fast idle
Old 21 Feb 2010, 09:27 pm
Default Problems with a fast idle
Hi I just changed my valve cover gasket and now my idle is off. It "hangs" at about 2500rpm and it takes a bit to come down to 1000rpm. Thats were is idles at. My car is a 2003 GT 5-speed. I have pulled the intake off and on about 3 times and checked and rechecked everything. The only thing i can think of is the Idle air control valve. I have taken it apart and cleaned it out. the thing was loaded with carbon. The idle speed has gone down but it still is not at the normal setting. Anyone have ideas?
Old 22 Feb 2010, 06:06 am
Default Re: Problems with a fast idle
Two things. Under the IAC there's a TP (Throttle Position) sensor. Check to make sure that the electrical connection is tight. Second: on the picture of my engine (non turbo) you should also have the two cables that run across the engine. One is for the cruise control and one is the throttle cable. Make sure the cables are free to rotate and go all the way back to the resting position.
Old 22 Feb 2010, 07:04 am
And check all vacuum lines!
Also check the PCV valve - cheap enough to replace it.
Old 22 Feb 2010, 04:44 pm
Thanks for the replies guys. Quicksilver, I check and re-checked and re-re-checked the vac lines. Crewzin, I learned about the IAC from some of your past posts. So I took it out and cleaned her up. Now the car is "drivable". The idle settles at about 1000rpm. As I come to a stop it is real slow to drop RPM's. So I ordered up a new one. I also ordered a new PCV valve from the dealer. Is it just my location or do they not sell them at the auto parts store? I had to go to the dealer. So now I wait for it to come in the mail. This is my fist time on this board so thanks a bunch for the help full info!
Old 22 Feb 2010, 04:49 pm
Do you have defrost on? That turns on the A/C and with A/C on idle is higher...
Old 22 Feb 2010, 05:07 pm
QSD is right on the money. The idle will raise with any condition that the compressor comes on (defrost/normal A/C). Normal idle is about 750rpm's and up to 900-1000 with the compressor on.
Your better off with and component from the dealer. Many owners have gone for aftermarket sensors and have them not work or fail shortly after fitting.
Old 22 Feb 2010, 08:46 pm
No the A/C is off and so is the defrost. I ordered the IAC already so I guess I'll have to see how that works out. Hopefully the new part will fix the problem. Fingers crossed.
Old 25 Feb 2010, 05:03 pm
Just want to follow up (hopefully it will help someone later). Installed the IAC and that fixed the problem! Thanks for the help guys!
Old 25 Feb 2010, 05:09 pm
Thanks for the update. Glad you got it fixed.
Old 25 Feb 2010, 06:27 pm
Thanks for posting the cure - that really helps others.
2004 Rough Idle A/C problems jiddypop Tech & Performance Forum 12 13 Oct 2012 12:47 pm
06 cruiser idle/fan problems TFD Tech & Performance Forum 10 10 Jul 2009 07:26 am
2006 Pt cruiser idle problems Germando Tech & Performance Forum 1 21 Aug 2008 06:59 am
Fast idle in cold weather? katydidindeed Tech & Performance Forum 1 06 Jan 2002 08:07 am
