PT Starting Issue - Please Help Me Out Here
Old 23 Feb 2010, 01:39 pm
Exclamation PT Starting Issue - Please Help Me Out Here
Hey everybody, I have a 2003 PT Cruiser. It has been working wonderfully up until now. I insert my key, turn... and the engine starts (sounds beautiful, like new)... then idles for 2-3 seconds, then just dies. What in the world is causing this?
Old 23 Feb 2010, 02:23 pm
Default Re: PT Starting Issue - Please Help Me Out Here
Jake,
Does the engine light come on at all? If it does they'll be a code set in the computer that will help us diagnose your problem.
Old 23 Feb 2010, 02:35 pm
Sounds like it might be the anti-theft protection. Same key you've always used?
Old 23 Feb 2010, 02:46 pm
Your right Don, forgot all about that. The security system will allow the car to start and then if it doesn't recognize the right code it will cut the engine off.
I found this on PT Do-It-Yourself.net:
Dick Reed wrote, I had a problem with my 2001 PT that I would like to share with other owners. Initially, the PT spontaneously started the security system panic alarm. When I tried to start the PT it ran 3 seconds then quit, then would not turn over at all. (Normally, the engine will shut down after 3 seconds if the sentry transponder key code does not match the code programmed into the Sentry Key Immobilizer System (SKIM)). I called the dealer and he suggested charging the battery, which resulted in no change. I paid for the tow and 1 hour labor, and they said they charged it (With The Key On: dealer didn't mention that when I called) and everything was fine. One year later, in 10-degree weather the issue occurred again. The alarm went off spontaneously. The PT started and quit within 3 seconds then wouldn't turn over. I started the charging process with the key on, not taking much current. I decided to clean the battery cables and terminals, which resolved the problem. Apparently, when the connection is bad, rather than turn over slowly, it shuts down the sentry and/or electronic system. I hope this helps save someone else some money and aggravation.
Old 23 Feb 2010, 03:57 pm
Hahaha, I think it was the key issue! I will keep you all updated on this issue. That's pretty cool, I had heard of SKIM a long time ago, but ignored it, guess it does affect me, lol. And yes, I was using a different key both these times.
Old 23 Feb 2010, 05:27 pm
Hey, I'm getting pretty good at this...
Old 23 Feb 2010, 08:03 pm
Yes you are Don. Keep up the good work.
Old 24 Feb 2010, 10:41 am
William_F's Avatar
HI HO SILVER!! AWAY!!!
Not too far away though, because you are quite helpful when we have questions
'03 Not starting GunnerIke Tech & Performance Forum 6 29 Oct 2009 09:55 am
01 PT Problem with starting car Vengence General PT Cruiser Discussions 1 04 Apr 2009 01:29 pm
starting up problem packrat007 Tech & Performance Forum 11 15 Aug 2008 04:38 am
Just Starting air4cefamily General PT Cruiser Discussions 3 29 Mar 2008 08:41 pm
Problems Starting hhomer PT Cruiser Convertible Forum 0 29 Aug 2004 08:25 pm
