Power Door Locks Remote Key Entry Module
Old 25 Feb 2010, 07:28 am
Default Power Door Locks Remote Key Entry Module
02 pt lock problem. If I hit the lock button inside nothing happens. If I use the remote the lights flash horn chearps. I ohmed out both door switchs thier ok. Ran seprate power to door lock motor locked & unlocked. I removed dash cover to access remote key entry module it cliks but I didn't get a signal out. The dealer say they can't just check the RKEM they have to check motor & swichts as well T or F. DRB 3 scan tool should let them check RKEM since it programs RKEM. Any help Thank You
Old 25 Feb 2010, 06:25 pm
Default Re: Power Door Locks Remote Key Entry Module
Sure sounds like the RKEM is toast. It is probably over-riding the switch in the car - can you disconnect the RKEM and prove that?
Old 25 Feb 2010, 06:30 pm
I see you posted this multiple times - no need for that...
Old 25 Feb 2010, 06:38 pm
2nd post was a srew up didn't mean to sorry. about the locks if i unplug the RKEM the door switch should still work T or F. Thank you for your help.
Old 25 Feb 2010, 06:42 pm
Yeah, if the switch works with RKEM unhooked, it pretty well proves RKEM is your problem.
Old 26 Feb 2010, 07:00 am
Will a 01 RKEM work on an 02. It's used would the dealer have to flash it?
Old 26 Feb 2010, 11:50 am
Pretty sure'01 & '02 are the same - if you have both fobs you can try programming it - dunno if dealer has to be involved...procedure (I think) is in manual.
Old 26 Feb 2010, 04:08 pm
I unpluged RKEM hit drivers door switch NOTHING. Is thier a fuse somewhere im not finding? Any steps or ideas would be apreciated.
Old 26 Feb 2010, 04:24 pm
There's two fuses related to the Remote Keyless Entry on your model. The No#3 fuse (20A) in the interior fuse box and the No#10 fuse (40A) in the PDC (Power Distribution Center) in the engine compartment.
Keyless entry unlocks driver door only- indoor locks not working Candace Tech & Performance Forum 9 14 Oct 2009 05:48 pm
Remote Keyless Entry Module chris15 Sound and Security Forum 2 29 Jun 2009 06:08 pm
power door locks deederz Interior Accessories Forum 6 22 Feb 2006 06:23 pm
Your power door locks ever do this?? Ripped General PT Cruiser Discussions 10 09 Apr 2004 02:20 pm
