Park Brake Warning Light
Old 04 Mar 2010, 03:12 pm
Default Park Brake Warning Light
Comes on under acceleration.
I'm just wondering if backing the car up often adjusts the brakes.
I've noticed that over the last while, when I start from a stop, the park brake warning light comes on. It's staying on for longer, recently. Seems to go off when I stop accelerating, and it does not come on when I actually put on the brakes.
I'm wondering if, under acceleration, a little tension is put on the park brake cable, and my habit of backing into parking stalls has adjusted the brakes to where they're just about dragging.
Or, could it be that dust and debris is packing up the brake drums? I do a substantial amount of driving on gravel roads.
Any ideas? (apart from "get a manual, and jack the thing up to have a look" I mean I'm going to do that when I get a few days off anyway.)
Maybe. Maybe not.
Old 05 Mar 2010, 12:36 pm
IMIEIW's Avatar
Send a message via AIM to IMIEIW
Default Re: Park Brake Warning Light
I'm almost sure that backing up and stopping only adjusts drum brakes but to have the light come on means one of a couple of things. Either there is a bad sensor or there is actually something wrong with your brakes. I would check them out ASAP because even though we like to cruise, sometimes we have to stop.
Old 05 Mar 2010, 12:49 pm
Try looking at the brake reservoir. It could be a little low and when you take off from a start it pushes the fluid towards the back of the reservoir bowl and away from the sensor so it thinks your low in fluid.
Old 05 Mar 2010, 04:59 pm
Yup - it's the first sign your pads are wearing down. If you do add fluid, only add a little, because when you change pads and push in the pistons, the fluid might overflow.
You ought to start planning on replacing pads.
Old 06 Mar 2010, 12:24 am
Cool!
Thanks, guys!
Maybe. Maybe not.
Intermittent oil warning light pt2 sawdust123 General Turbo Discussions 25 03 Apr 2017 07:41 am
Oil warning light on...oil topped off? wheelgarage Tech & Performance Forum 32 23 Jan 2011 07:54 am
rear park brake shoes AlexJB General Turbo Discussions 10 12 May 2008 02:33 pm
Brake Light Warning and chime sound. GTinAZ General PT Cruiser Discussions 14 14 Dec 2004 09:33 am
brake light warning onyx pt General Turbo Discussions 7 27 Apr 2004 02:51 pm
