Is it possible to get 62.4 litres of Gas into my 56.7 litre tanK??
Old 12 Mar 2010, 11:37 am
Default Is it possible to get 62.4 litres of Gas into my 56.7 litre tanK??
I went to the Gas station yesterday, full serve and the tank was pretty much empty. I watched the guy and he did the norm. but when I looked at the Gas Pump and the receipt it says the put in 62.2 litres (that is 16.43 Gallons) into my 56.7 litre gas tank (15 Gallons)
I looked in the manul and it says Fuel Capacity is (Approximate) but really can they get that much more GAS into it.
I think I am being ripped off, what do you all think.
HELP
Sheila
Old 12 Mar 2010, 02:12 pm
Default Re: Is it possible to get 62.4 litres of Gas into my 56.7 litre tanK??
What I do to see if gas stations are being honest (my nature) is to stop the pump at exactly 1 gallon and see if it matches the price they are advertising. I've found they could be off by a couple of cents per gallon, to their side, which makes the price I'm paying more than what they are displaying on their sign.
Back to your question. if you were really, really low, like almost on fumes, there's maybe a gallon in the fuel pump and lines but if your that low, or not even that low your doing your car harm. The fuel pump (inside the tank) is lubricated and cooled by the gas inside the tank. Going lower than 1/8 tank on numerous occasions can burn the pump up. Plus, the bottom of the tank always has some residue which you don't want the pump to pick up and send it to the injectors.
Old 12 Mar 2010, 05:24 pm
If they are topping it off it will be only a matter of time before your charcol cannister is saturated with gas and you will be forced to buy another one. Not cheap either so I wouldn't let them top it off. When it clicks off that is it.
Gasoline Smell coming in Heater Vents 2002 PT Limited
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 12 Mar 2010, 05:48 pm
Did you get two chimes before you got gas? Needle deep in the red? Possible if they filled up the filler neck with gas.
Old 12 Mar 2010, 06:02 pm
ARGH! Bye bye fuel pump.
The gas tank.. ucantcme General PT Cruiser Discussions 47 22 Aug 2016 11:01 pm
I'm only getting 120Miles to a tank.... rubsnick General PT Cruiser Discussions 20 03 Oct 2009 09:02 pm
Vaccuum Tank?? notadodge Tech & Performance Forum 5 09 Mar 2008 11:27 am
Gas Tank BruisersCruiser General PT Cruiser Discussions 5 14 May 2004 04:42 pm
Performance chip for Euro 2 litres Craig Tech & Performance Forum 0 12 Oct 2001 03:52 am
