Changed my spark plugs, now I've some problems
Old 13 Mar 2010, 09:19 pm
William_F's Avatar
Default Changed my spark plugs, now I've some problems
Today I changed the plugs and wires on the '06 LE. I thought everything went fine, but something isn't right.
When I cranked up the car, the car's idle shot up to 2500 RPM right away. The check engine light came on and there is a misfire.
I ran out of day light, so I'll have to deal with it tomorrow, but I took it to Auto Zone to have the code read figuring if I knew which cylinder wasn't firing right I could save some time when I pull it apart tomorrow.
They reading came back saying it was the MAP sensor. When I checked it out, it looked like I'd installed it upside down. So, I flipped it over and thought that's all, but it's not.
I took it for another test and it was still misfiring. In addition to the misfire, when I floored the gas, there was no response. The car acted like it wanted to stall and the engine revved, but there was no acceleration for several seconds.
I am puzzled as to what I could have possibly done to the car. I got an extended warranty from the bank when we got the car, but it won't cover anything I broke doing maint work.
Old 14 Mar 2010, 12:38 am
Dino's Avatar
Default Re: Changed my spark plugs, now I've some problems
Take the plugs out and wires off, re-gap and check the plugs and reinstall the wires. What kind of plugs and wires did you get and what did you gap them at? Maybe you knocked something loose or something. Good luck Bro
Old 14 Mar 2010, 08:04 am
Good advice. Recheck everything, take your time and use dielectric grease on the wire ends and anti-seize on the plug threads.
Old 14 Mar 2010, 10:27 am
William_F's Avatar
I used Champion Platinum Plugs and NAPA's premium wire set. I set the gap at .40.
I figured I was going to have to tear it all apart today and see what was going on. If it was just a misfire, I would lean towards something with the plugs or wires. The high idle is what's really got me puzzled. I've never had that sort of problem before.
I did that when I put them in. At least they'll come out easier today than they did yesterday I'm off to grab my tool box and crack the hood open again...
Old 14 Mar 2010, 10:34 am
A high idle sometimes means some sort of vacuum leak if it doesn't tun out to be something electrical or an unplugged sensor.
Old 14 Mar 2010, 11:27 am
William_F's Avatar
If by leak you mean leaving a hose disconnected from the manifold, then it was indeed a leak
I went out to the car and popped the hood to start taking thing apart and immediately noticed a hose that had been left disconnected. I popped it back and fired up the car and it idled a little higher than usual at about 1200. I went for a drive through the neighborhood and it's running smooth and accelerating on demand now
When I turned the car off and restarted, it idled at 800 or so so it seems to be back to normal.
The only remaining issue I have is how do I reset the check engine light?
Old 14 Mar 2010, 11:43 am
Glad you found your problem and YES by leak I meant either air getting in from a disconnected hose or in/out thru a crack in the manifold or intake hose.
To get rid of all stored faults in the computer and the check engine light, take off the negative battery cable for about 5 minutes. You shouldn't lose any of your pre-set radio stations. The car might run a little ruff for a minute or two when first starting it up again while the computer learns some of your stored settings. Drive normally (fast or slow depending on your type of driving) so the computer learns that too.
Old 14 Mar 2010, 03:06 pm
William_F's Avatar
Thanks
I always appreciate how you guys here have my back when I really need some help.
Old 14 Mar 2010, 08:13 pm
Dino's Avatar
Glad you worked it out, without getting all greasy with a bloody knuckle or two
Old 14 Mar 2010, 09:06 pm
William_F's Avatar
Well no bloody knuckles anyway
changed spark plugs... eyeguy05 Tech & Performance Forum 14 01 Feb 2010 04:08 pm
Changed Plugs ejstith General PT Cruiser Discussions 16 16 Nov 2009 11:01 am
Just changed my plugs & wires... Travis2k7 Tech & Performance Forum 6 22 Jun 2009 09:16 am
Changed Plugs & Wires infernocruisr01 Tech & Performance Forum 4 30 May 2007 06:04 pm
Just changed plugs & wires gonzomania Tech & Performance Forum 2 04 Aug 2005 05:13 pm
