Acceleration Sensor
Old 14 Mar 2010, 10:59 am
Default Acceleration Sensor
Has anyone had any problem this is bastard?
I got a 03 PT Cruiser Limited Edition 2.0 Auto.
Maintenence "fault" light came on, took it to the garage. Performance dipped slightly but it still drove.
reset light and carried on with life, then a couple of weeks later - light comes back on. Back to the Garage paid around 160 to replace sensor (inc labour and vat) now less than 3 weeks since the replacement the problem comes up again.
its doing my head in, half of me is thinking the Garage is bending me over and the other half is thinking oh Chrysler must be a tough car to fix (ie the computer)
The guy at the Garage has said it is probably due to the computer not reconizing the new Sensor?
sorry for long winded story thought id explain myself
Cheers
Alex "Cookie"
Old 14 Mar 2010, 05:20 pm
Default Re: Acceleration Sensor
Alex, welcome to the forum.
In order to help we have to know what the fault code was that made the engine light come on. Sounds like your mechanic is throwing parts at the problem with a good diagnosis.
In order to find the fault code read this:
How to retrieve fault codes.
Old 15 Mar 2010, 08:22 am
Garage may merely be incompetent.
Get the codes and then you can Google the code and be ahead of the garage.
Old 15 Mar 2010, 08:31 am
I have seen the code from the garage, I did t see the code but it said sensor on accelerator moved or something like that. Not sure if because of the pedel being moved (pressed down to drive?) I'm going back to see them tomorrow hopefully thY have spoken with Chrysler.
Will keep you posted
cook
Old 16 Mar 2010, 02:22 am
Are they using an oem sensor, or aftermarket?
-Chris
Acceleration problems ConspiracyTheory Tech & Performance Forum 9 10 Nov 2014 09:26 am
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
Pinging on acceleration coolvanillagt Turbo Performance 24 15 Oct 2005 04:08 pm
Acceleration problems SJGW Tech & Performance Forum 2 27 May 2005 09:19 am
Best Shifting For Acceleration??? kidturbofan Turbo Performance 7 13 Sep 2003 02:43 pm
