Two horns on one wire?
Old 14 Mar 2010, 01:41 pm
Default Two horns on one wire?
I replaced the horn on my 2003 PT with high note NAPA horn. I would like to add a low note horn too. Is it ok to split off the wire attached to the high note horn to power the low note horn? If not how would I go about getting power to the 2nd horn?
Also, the original electrical horn wiring looks to by like 18 gauge but I used 14 gauge wire while the instructions I was going by from another PT forum said to use 10-12 gauge wire. Can anyone clarify what gauge wire I should be using?
Thanks.
Old 15 Mar 2010, 08:41 am
Default Re: Two horns on one wire?
Unless you're a cab driver, your horn shouldn't get extended use so the one wire should be okay.
To add a second, what I did for my Aoogah horn is get an inline fuse and a relay. From + of battery, put in inline fuse and go to contacts of relay to horn. Use the horn switch to go to the coil of the relay.
Old 15 Mar 2010, 09:27 pm
soonercruiser's Avatar
Talking Re: Two horns on one wire?
I did it on soonercruiser, and I am having no problem!
Mine came with the low tone; and I added a high tone highway blaster from Autozone.
Now, I have a real horn.....and I do use mine like cab driver!
Frank, aka SOONERCRUISER,
Old 16 Mar 2010, 06:50 pm
Send a message via AIM to slayerdarkcross Send a message via MSN to slayerdarkcross
Junkyard horn
hella horns dbraveman General Turbo Discussions 29 21 Apr 2010 10:28 pm
Air horns and OEM horns? At the same time? DJmart Tech & Performance Forum 12 29 Dec 2007 09:31 pm
Horns? KingKole02 General PT Cruiser Discussions 1 05 Oct 2004 01:38 pm
Who here knows anything about Aooga Horns? Konkeler General PT Cruiser Discussions 5 21 Aug 2004 02:28 pm
Horns turbomangt General PT Cruiser Discussions 12 25 Sep 2003 03:18 pm
