timing belt
Old 15 Mar 2010, 08:05 pm
Default timing belt
My timing belt broke while I was riding home from work. I wasnt going very fast,
I'm worried that I might have damaged my engine though. the code said camshaft sensor but It was the belt. My mechanic is replaceing the belt and water pump .. is that enough?
Old 15 Mar 2010, 08:14 pm
Default Re: timing belt
Beside the belt and water pump, Chrysler changed the tensioner in 2003 and it does wear out so you should put a new one in. The serpentine belt and the alternator belt should also be changed at the same time if you hadn't already done so. You won't be able to tell if the valves hit each other until you get it back going again. There's a simple test your mechanic can do to find out. The good thing is the valves can't hit the pistons.
When the belt broke, the camshaft sensor and the crankshaft sensor both saw that there was no more signal coming in because the engine wasn't tuning over anymore. Getting one or the other fault code from crank or cam is normal.
Old 07 Apr 2010, 11:24 am
I have an 01 Cruiser, can you tell me where the marks are to be? There seems to be some debate, and you seem to know the right information. I did the nail polish trick befor I started to change the belt. When I put the belt back on it wouldnt start. I'm very mechanically inclined, so this didnt make sence. I did the rookie thing and moved the belt after turning the motor over a few times, and now I'm, not sure that the marks are correct. Can you help me, Ted
Old 07 Apr 2010, 11:26 am
I for got to mention that I changed the belt due to a bad water pump
Old 07 Apr 2010, 02:24 pm
Ted,
If your talking to me, someone else will have to answer that question because I just let my mechanic do the whole job. There has been some pictures posted about the timing marks so if you do a search for "timing" or related subjects I'm sure you can find out more information.
Old 07 Apr 2010, 02:40 pm
Thank you, I have purchased a Chiltons Manual, and all the spec's are there. Thank you for your time,
Timing belt weighit General Turbo Discussions 27 26 Dec 2012 06:49 pm
timing belt greg55 Tech & Performance Forum 1 08 Mar 2010 09:06 pm
Could it be the timing belt? mbmouse Tech & Performance Forum 4 12 Jan 2009 09:01 pm
timing belt help bowtie_65 Tech & Performance Forum 2 29 Nov 2008 02:12 am
timing belt clevelandmike Tech & Performance Forum 2 08 May 2006 12:28 am
