some PT GT problems Hesitation
Old 16 Mar 2010, 10:35 am
Default some PT GT problems Hesitation
Hey guys, I'm getting a hesitation or a stutter when I am really getting on it. The car feels strong as it pulls to red-line but their are noticeable stutters at about 4000K to red-line. I Just did a tune up ( wires, plugs gapped to .45, air filter, oil change). On top of all that I have just changed the air idle control valve, valve cover gasket and the air intake gasket (which fixed a trouble code for #4 cylinder misfire). Now don't get me wrong this is not a "bucking" feeling. It just feels like it's getting held back. I have tried some fuel system cleaner and I always run 93 octane. My god I didn't realize that i put that much into the car in the past month .
Old 16 Mar 2010, 11:01 am
Default Re: some PT GT problems Hesitation
Did you have the problem before the tune up? If not I suggest you go over the plugs and wires. The gap for a turbo seems wide according to what the turbo guys are using, especially if your using the iridium plugs. Dielectric grease on all the wire ends will help make a sure contact and also keep dirt and moisture out.
Old 16 Mar 2010, 11:23 am
Agree (as usual) w/Crewzin-
When I saw your gap - that's big even for a non-turbo - try 0.035 and report back!
Old 22 Mar 2010, 05:42 pm
Angry Re: some PT GT problems Hesitation
Okay I checked and my gap is @ .35. So i don't think thats the problem. On the way home from work I got a 0440 code. Could it be related? I don't know. Help....
Old 22 Mar 2010, 05:46 pm
From PT Do-It-Yourself.net ......
I have a 2003 TE PT with 65k miles. My check engine light keeps coming on. It has been to the shop around 6 times and they can't seem to figure out what the heck is wrong with it. The code reads P0440. I have changed the fuel cap, but it didn't work. Brian, from Texas.
P0440 - General EVAP System Failure
Possible causes include:
Visual and Physical Inspection
Evap Purge Solenoid Vacuum Supply Inspection
Evap Purge Solenoid Stuck Closed
NVLD Switch Operation
(Z1) Ground Circuit Open
NVLD Assembly
NVLD Switch Signal Circuit Open
Evaporative Emission Leak Detection
PCM
If you mean, by shop, a local automotive shop, take it to a DC dealer. They have the necessary equipment and experience to diagnose most faults. If you are using a DC dealer and they have been unsuccessful in resolving it obtain a second opinion from another DC dealer.
You can DIY the visual and physical inspection of the Evaporative Emission system, but to check the remainder of potential causes, a DRB III scan tool, diagnostic manual and assorted other automotive test equipment is necessary.
Perform a visual and physical inspection of the entire Evaporative Emission system. Check for the following conditions:
Hoses disconnected or left off
Holes or cracks
Loose seal points
Evidence of damaged components
Incorrect routing of hoses and tubes
Fuel Cap left off or bad gasket seal
Old 27 Mar 2010, 07:57 am
I was looking at the pt again. I sprayed some starter fluid around the back side if the aluminum air intake. The idle smoothed out. So thats telling me I have some kind of leak around the gasket (that i just replaced). My question is could it be a leak at the valve cover gasket? Or would that just leak oil?
Old 27 Mar 2010, 09:49 am
Intake gasket leak.
Old 31 Mar 2010, 06:01 pm
I pulled the intake again and their is an oily substance on the gasket. It looks like it is seeping from the intake tract to the outer edge. So that is telling me that if the oil is seeping out the intake then the air is leaking too. So, how do I seal this? I was thinking that just replacing the aluminum intake with the composite would go along way to help solve this problem. But in the mean time do you think some RTV would do the trick?? Thanks guys.
Old 03 Apr 2010, 09:40 am
Well I took it into the "professional" mechanic. I will post what they come up with.
Old 05 Apr 2010, 04:15 pm
Welp, the pro told me that the LOWER intake manifold gasket was bad... DUH! 150 bux later it's all done. Rock steady idle. Hope this helps someone in the future.
Hesitation DukeofWagner General PT Cruiser Discussions 1 26 Oct 2008 06:29 am
Slight hesitation DMW General Turbo Discussions 3 03 May 2005 03:36 am
Hesitation Mean Green Turbo Performance 6 31 Dec 2004 08:42 pm
Get rid of the WOT hesitation... Cal Cruzer Turbo Performance 2 15 Jun 2004 01:02 pm
hesitation JST CRZN Tech & Performance Forum 6 23 Oct 2001 04:49 pm
