Dead PT need help
Old 25 Mar 2010, 08:43 pm
Default Dead PT need help
Here is my problem: Car died in the middle of traffic. Cranks but doesn't start. It's throwing error code P0440 and P0441. I have no idea what is wrong or how to fix it.
Car is a 03 2.4 NA engine touring edition, no mods. everything is stock
Guy at the shop noted it may be the crank shaft or cam shaft sensors.
Please help!!
Old 25 Mar 2010, 09:25 pm
Default Re: Dead PT need help
Your codes have nothing to do with the Cam or Crank sensors:
P0441 Evap Purge Flow Monitor -Insufficient or excessive vapor flow detected during evaporative emission system operation.
A Diagnostic Trouble Code indicates that the Powertrain Control Module has recognized an abnormal condition in the system. DTC's are the results of a system or circuit failure, but do not directly identify the failed component or components.
Possible causes for P0441 include:
Intermittent Condition
Checking Evap Purge Solenoid Functionality
Evap Purge Solenoid Vacuum Supply
You will need a DRB III scan tool and diagnostic manual to troubleshoot the issue.
P0440 - General EVAP System Failure
Possible causes include:
Visual and Physical Inspection
Evap Purge Solenoid Vacuum Supply Inspection
Evap Purge Solenoid Stuck Closed
NVLD Switch Operation
(Z1) Ground Circuit Open
NVLD Assembly
NVLD Switch Signal Circuit Open
Evaporative Emission Leak Detection
PCM
You can DIY the visual and physical inspection of the Evaporative Emission system, but to check the remainder of potential causes, a DRB III scan tool, diagnostic manual and assorted other automotive test equipment is necessary.
Perform a visual and physical inspection of the entire Evaporative Emission system. Check for the following conditions:
Hoses disconnected or left off
Holes or cracks
Loose seal points
Evidence of damaged components
Incorrect routing of hoses and tubes
Fuel Cap left off or bad gasket seal
Old 25 Mar 2010, 10:39 pm
bama7474's Avatar
NVLD Assembly
PCM
Holes or cracks
Loose seal points
Cruizin, after reading several posts I'm beginning to believe you've been sent down by God to help his people with their PT Cruisers problems I'm glad to have you on our side, owning a PT has now become that much better knowing "Cruizin" is there putting AAA out of business!!! LOL. Thanks Cruizin, look forward to learning more about my little blue baby!
2005 PT Cruiser
Touring edition
2.4L DOHC
Old 26 Mar 2010, 06:43 am
NVLD Assembly
PCM
Holes or cracks
Loose seal points
Thanks for the info, but would any of these faults cause the to not start?
Old 26 Mar 2010, 07:01 am
Cranks but no start? Timing belt?
2005 Limited Turbo-Lite, auto in Cool Vanilla
Old 26 Mar 2010, 07:58 am
Dino's Avatar
Agree, whats the mileage on the PT?
Old 26 Mar 2010, 02:59 pm
just crossed 100K on the engine.
Old 26 Mar 2010, 03:10 pm
Timing Belt, definately!!!
PT Dead - Need Help! silver7 Tech & Performance Forum 14 08 Mar 2010 11:50 am
Pt dead Maineiac General PT Cruiser Discussions 5 21 Jul 2009 10:05 am
PT Dead in Desert millsm64 Tech & Performance Forum 3 14 Sep 2007 07:16 am
PTE Dead? Mean Green Non-PT Discussions 8 14 Jan 2005 02:48 pm
Dead, again renichms General PT Cruiser Discussions 6 03 Jul 2003 10:42 pm
