can't find radiator drain plug
Old 27 Mar 2010, 09:33 pm
Default can't find radiator drain plug
Sounds ridiculous right?
I have a 2002 basic Pt Cruiser.
There is no obvious drainplug that I can feel or see. I have a Haynes manual for Cruiser models 01-04 that shows the underside of a pt cruiser --- which is identical to mine except for the drainplug which I'm passing over. I've even used the gridlike bottom of the silver oil(?) pan where the oil filter threads into and a few other spacially contextual clues to approximate where the plug should be --- but I don't see it.
I see where it might be, where there is instead a nut threaded around a standard bolt with two holes or identations in its head, but don't want to risk loosening the wrong thing, so...
What should I do? Does someone have a photograph of what my drainplug should look like. Should I take a few photographs of the underside and allow forum members to pinpoint my drainplug?
Can I drain the coolant system by disconnecting the lower radiator hose? If I can, are there any reasons I shouldn't?
Old 28 Mar 2010, 10:40 am
Default Re: can't find radiator drain plug
The drain plug is on the bottom driver's side of the radiator. Keep in mind, that being 8 years old, your car may have an aftermarket radiator installed. If this is the case and you don't have a drainplug, you'll need to remove the lower hose.
-Chris
How to replace radiator drain plug? hotdog789 Turbo Performance 2 22 Feb 2010 11:57 pm
Oil Drain Plug! Tech General PT Cruiser Discussions 9 19 Oct 2009 01:19 am
coolant leak from the radiator drain geronimo Tech & Performance Forum 1 19 Jul 2009 02:55 pm
Radiator drain plug Mapper Tech & Performance Forum 16 15 Jul 2009 08:06 pm
oil drain plug tagreen95354 Tech & Performance Forum 14 05 Feb 2006 09:37 pm
