trouble code p0601
Old 29 Mar 2010, 02:14 pm
Default trouble code p0601
I got this message the other day on my 2001 touring edition manual. Research says it might be the computer is shot! ouch. The only issue with the car is it idles fast until you come to a complete stop. Push in the clutch as you come to a stop and the idle speed is about 2300 and then drops to 900. Could it be the throttle body sticking ?...I cleaned it but only with spray. No change Did not take it off. Or could it be the throttle position sensor (TPS) or the (IAC) idle air control? If I replaced one or both would that fix the problem?
Old 29 Mar 2010, 02:48 pm
Default Re: trouble code p0601
Possibly the IAC. You can try and take it off, take it apart and clean it but if your not sure what your doing, you can just replace it.
Old 30 Mar 2010, 10:02 am
I think that I will go the replace route. Thanks for the tip.
Trouble light code rainier42 Tech & Performance Forum 2 22 Feb 2010 04:48 pm
Error Code P0601 - Help SlowwCory Tech & Performance Forum 2 20 Aug 2009 12:35 pm
trouble code cel, on power steering issue 2001 PT drej79 General PT Cruiser Discussions 5 14 Aug 2009 09:13 pm
trouble code Paw General Turbo Discussions 21 20 Oct 2003 11:46 pm
trouble code Punch Tech & Performance Forum 1 17 Aug 2003 06:21 pm
