Rear Running Lights out.....need help
Old 01 Apr 2010, 09:47 pm
Default Rear Running Lights out.....need help
I got headlights,rear turn single,rear brake lights,and flashers. But the rear running lights do not work. I have checked all the fuses both under dash and the engine box..and dont see anything out there..any help please
Old 02 Apr 2010, 01:54 am
Default Re: Rear Running Lights out.....need help
By rear running lights, do yo mean taillights? Check the bulbs first. They're dual filament bulbs, so just because the brake lights work doesn't mean the taillight filament isn't burned out.
-Chris
Old 02 Apr 2010, 09:29 am
He may be in the UK, or some other place overseas. I seem to remember reading on here, or maybe another forum that the back up light housing there is used as rear running lights with bright bulbs in them. Maybe for when fog is thick.
Someone correct me if I'm in error.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Old 02 Apr 2010, 11:09 am
I have had past problems with moisture getting in the read light housing and blowing the bulbs,however their is still brake lights and turn signal and flashers. I can check the bulbs but what are the chances that the filiments in both bulbs blew at the same time? Again I am speaking of no lights as in parking lights...I do have brake lights and turn signal
Old 02 Apr 2010, 12:46 pm
OK, more questions: What year is your car? Are you in the UK? Does the bulb over the rear license plate light up? Does the front parking lights light up?
garyerrol,
I was in the UK for 12 years. Yes, all European models have an extra fog light in the rear (some have two) that carries a 21watt bulb for extra brightness and it's only to be used during fog. It's on a separate circuit and separate switch all by itself. You can see it here and overseas when the driver accidentally leaves that switch on and they drive around with that extra bright red light glowing.
Old 02 Apr 2010, 04:31 pm
Im in Texas,the Pt is a 2003.I just checked the parking lights and noticed the front parking light are NOT working as well,however the white light over the lincense plates are comming on...now Im really confused!!!
Old 02 Apr 2010, 05:13 pm
OK, there's 11 pages of wiring diagrams for all the exterior lights. You need to check again all the fuses directly or indirectly related to them. Under the hood , fuse #12. In the interior fuse box check: #2, #6, #18, #19 and #20.
Old 02 Apr 2010, 06:02 pm
I checked all the fuses you listed and they were all in working ored. I rechecked the front parking lights and noticed that they DO work(sun was shineing on them earlier),I broke down and removed the rear light lense and noticed BOTH...yes BOTH read bulbs were blown out!!! What are the chances of both blowning out at same time..lmao!!!! Something so simple im kicking myself in the ass for not checking first...I have had on ongoing problem with moisture entering and blowing the bulbs..so now what are the suggestions to keep moisture out of light houseing!!! Oh by the way I just love this site....You guys are awsome!!!
Old 02 Apr 2010, 06:08 pm
Take the lights out (as you did) and make sure the little felt/rubber gasket around the bulb holder is all in one piece and making a good seal when you twist everything back together. Then look all around the edge and make sure there's no broken seam that would let air/water in.
Old 02 Apr 2010, 07:06 pm
A little dielectric grease around the bulb MAY help as well.
Daytime Running Lights SteveANJ General PT Cruiser Discussions 6 05 Mar 2008 09:38 am
Rear LED signal Lights Islandmahn Exterior Accessories Forum 3 16 Dec 2007 10:46 am
daytime running lights module frances General PT Cruiser Discussions 14 09 Sep 2004 03:47 am
Running lights boater Exterior Accessories Forum 2 07 Jun 2002 11:01 pm
Daytime Running Lights Jay M Exterior Accessories Forum 0 14 Sep 2001 08:18 pm
