Ok so maybe I am an idiot...
Old 07 Apr 2010, 11:44 am
Thumbs down Ok so maybe I am an idiot...
However, I have searched and SEARCHED for the trunk release button in the car and I can't find it. I have owned the car for about two months and still can't seem to figure out if its just me or if there really IS NOT a release button inside?! hhheeeellppppp!!
Old 07 Apr 2010, 01:04 pm
William_F's Avatar
Default Re: Ok so maybe I am an idiot...
To the best of my knowledge, the trunk has to be opened from the outside unless you have installed an after market popper on it.
Old 07 Apr 2010, 02:14 pm
I believe convertibles have one in the glove compartment.
the rest of us - hit the rocker on the door to unlock all locks, then open hatch.
Old 07 Apr 2010, 04:29 pm
cruserdad1976's Avatar
well here is a quick update
I have a 06 touring non turbo auto now none of that matters but
if you hit the lock button on the keyfob and go into say walmart and them come out and put your key in the trunk or hatch and unlock it and go to open it the alarm will sound or the panic button whatever it is will go off and the only way i know to shut it off is to hit the open button on the fob
CRUZIN said one time that there is no way to open it from the inside
Old 07 Apr 2010, 05:10 pm
CRUZIN said what? Must have been another "CREWZIN". Like QSD said, if you hit the button on the inside of the door, all the locks including the hatch are then unlocked.
Dad, from what your explaining it sounds like you alarmed the vehicle when you hit the fob before you went into Wal-Mart and by just using the key to open it, it doesn't shut the alarm off, so you have to hit the fob. Not sure why it does that. I just tried mine and used the fob to lock and the key to open and it worked fine, no alarm. They have changed the electrics on the 06+ models as witnessed by doing away with the interior fuse box and lumping everything together under the hood. Maybe they changed the way the alarm works.
Trunk CANNOT be opened from the inside, unless someone has installed a aftermarket "popper".
Old 07 Apr 2010, 05:19 pm
Unless you hit the little black button on the door.
Old 07 Apr 2010, 05:37 pm
03GTCruiser's Avatar
But then again, that only unlocks the hatch. Does not pop it open.
2003 Pt Cruiser GT Autostick.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=9656&dateline=1247691  818
Ran 14.84 on my 5th run EVER down the track with the help of a fellow PTer and his 93 tune on his DSP.
*Stage 1, DSP w/93 canned tune, 3" o2 housing, 3" FWDPerformance downpipe with cutout. Bwoody solid mounts. AMX1397 TTAB with K&n drop in filter and airbox mod. Soon: AMX1397 lower pipe and AMX1397 uppipe with HKS BOV
* stock nsrt rims powdercoated black, chrome pillars.
* 3 gauge pod w/ aem wideband, Autometer ultralite oil pressure and 30/30 boost, Mopar 8" sub.*
Old 07 Apr 2010, 05:40 pm
Send a message via AIM to slayerdarkcross Send a message via MSN to slayerdarkcross
Every time I use the keys to open the car the alarm goes off. So I just use the fob to unlock and lock.
Also since I dont have a rear handle I can only open the trunk by using a switch that I relocated to my gas door.
2007 Touring Edition
Exhaust: Borla
Front: ODaddyO
Headunit: JVC KD-AVX77
Hood: ODaddyO
Intake: K&N Airraid
LED's: Oznium
Rear: ODaddyO
Speakers: Polk DB6501
Springs: Gold Line Slammers
Strut Bar: BTG Turbo
Subwoofers: Alpine SWR-1243D
Tailights: United Pacific LED Teardrop
Visor: Cal Cruiser
Check out my progress
My Facebook Add me!
Old 07 Apr 2010, 05:43 pm
Does anyone's POP open, mine unlocks and moves about 1 inch away from the lock when I hit the door button. Does that count as "POP OPEN" ?
I am an idiot Fodder4U General Turbo Discussions 2 25 Mar 2006 11:35 am
Gas Idiot Light Question Lin Toland General Turbo Discussions 8 13 May 2004 12:21 am
An idiot rear ended my PT ksquared11 General Turbo Discussions 11 29 Dec 2003 11:32 pm
Some Idiot Mean Green General Turbo Discussions 16 01 Dec 2003 07:24 pm
question from an idiot turbomangt Tech & Performance Forum 27 08 Nov 2003 04:55 am
