Code P0340 Cam Shaft Position Sensor A
Old 13 Apr 2010, 04:38 pm
Default Code P0340 Cam Shaft Position Sensor A
I know that this question has been asked a million times lol, i have read and searched all over the site, The problem that i am having is that i replaced the sensor and checked all the wiring with a volt meter and visually and have not found anything abnormal but im still getting the same code it will not go away when i erase it with my scanner it comes back before the scanner is event done erasing it, had the battery off for a whole night no difference,
the sensor is a mopar one picked it up from the dealer for $67 sad to say that it has not done any good, so aside from replacing the sensor and making sure all the wires are good what else could it be because the sensor is good and so are the wires but i still get the same po340 code and the car will not start, any help would be much appreciated.
Old 13 Apr 2010, 05:00 pm
Default Re: Code P0340 Cam Shaft Position Sensor A
Welcome to the forum.
What is your mileage? You'll also get that code if your timing belt has broken so if your anywhere near 100K on the odometer, better check your belt.
Old 13 Apr 2010, 05:41 pm
its my sisters car just trying to get it running for her for cheep to avoid dealer costs we all know how those can get, it has 119k on it ill go and check the belt now to see if that is the problem, and thanks for the quick response.
Old 13 Apr 2010, 06:09 pm
yep its the belt ahh that's going to be a great repair !
Old 13 Apr 2010, 07:16 pm
I wouldn't call it "great". The book calls for about 5 to 7 hours just for labor and they aren't kidding. To get clearance the engine has to be jacked up. We also recommend anybody doing the timing belt also do the water pump because it's in the same area and takes just as much labor hours to change that as it does the timing belt.
Luckaly it's a non-interference engine and not much damage can be done if the car was running when the belt gave way but the valves can hit each other so it needs to be checked out after the timing belt is changed.
Old 13 Apr 2010, 08:53 pm
lol i was just being sarcastic when i said great haha but thanks for the help man.
Old 13 Apr 2010, 09:01 pm
No problem. Good luck.
P0340 cam sensor code in 2006 cruiser deighter Tech & Performance Forum 13 12 Jan 2012 07:41 am
Code P0340 Cam Shaft Position Sensor A Leroy Western PT Forum 4 02 Apr 2010 04:01 pm
Code 340 Camshaft Position Sensor kghaddon Tech & Performance Forum 5 08 Jun 2009 09:09 pm
Cam Shaft Position Sensor Johns Steel Blue Tech & Performance Forum 9 15 Apr 2008 07:38 pm
cam position sensor 4SPEED Tech & Performance Forum 1 25 Sep 2006 04:16 pm
