Fog lights not working
Old 19 Apr 2010, 11:10 am
Default Fog lights not working
Any ideas on what is the problem?
Fuses = good
switch = ?
Power block under hood?
Works at PGW Autoglass
Formerly PPG Autoglass
www.wwiimemorial.com
Is Your Vet Listed?
Old 19 Apr 2010, 01:43 pm
Default Re: Fog lights not working
A number of people have had to change the MF switch, there is a posting on someone has repaired theirs, you'll have to search. MF = Multifunction Switch
Old 19 Apr 2010, 02:40 pm
As Hooligan said, the MF switch accounts for 99% of the failure for the fog lights. You checked the fuse (#8 interior), and only if your overseas is the #21 fuse in the Power Distribution Center, under the hood something to look at, so the easiest way to tell if it's the MF switch is to turn the fogs on and see if you have 12 volts up at the lights themselves.
Old 19 Apr 2010, 11:26 pm
twress's Avatar
I bought 2 different used PT a 01 LE and now a 02 Woody LE both had fog lights that didn't work when I bought them. It was the multifunction switch on both of them like Holligan and Crewzin said. The sad thing is my buddy that bought my crunched one had a guy who had a PT we took some part off of. I got the MF Switch off the car for free...guess what?? It was bad too.. common problem..easy fix.
ROUNDIN UP THE WAGONS 02 LIMITED WOODY, 89 CAPRICE CLASSIC
Old 20 Apr 2010, 09:49 am
Well the fuse in PDC under the hood was not there,,, problem????
MFS is located where? Are you talking about the headlight switch on the left side?
Is Your Vet Listed?
Old 20 Apr 2010, 10:05 am
As I said in my reply: only if you are overseas does the #21 come into play. The U.S. models don't have a fuse there.
Yes, the MF (Multi-function) switch IS the stalk on the left hand side that controls interior and exterior lighting. When buying a new one, you have to make sure you get the one with the fog light control. Some do not have that function and when switching the new one for the old one, there's a little black part that has to come off the old one and put onto the new control that controls the flashers.
Headlights, keyless entry & instrument cluster lights not working RTCruiser General PT Cruiser Discussions 2 06 Jul 2010 09:13 pm
Need a poll answered: Should I tint all my lights or buy euro/projector lights? 85_305 Exterior Accessories Forum 2 17 Jun 2009 08:38 pm
Fog lights not working SRT8guy General PT Cruiser Discussions 11 14 Apr 2009 08:13 am
Back up lights not working cheeseball Tech & Performance Forum 2 15 Apr 2003 01:43 pm
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
