Not level in back?
Old 19 Apr 2010, 07:30 pm
Default Not level in back?
Just noticed this...while looking at the car from the rear it looked higher on one side. Measured from the center of the rear fender to the ground and the right side is 1/2 inch higher that the left? What might be causing this? What is the fix?
Thanks!!
Old 19 Apr 2010, 08:12 pm
Default Re: Not level in back?
I also have a question to go along with that is there anyone else having an issue with the idling. I have a 2002 and it is idling real low in drive also does anyone know what site is good to get good speakers that fit in the pt
Old 20 Apr 2010, 06:48 am
Drunkgoat,
Your questions don't go along with what cnjvh posted whatsoever. If you go to the tech section for your idling problem and the sound and security section you'll most likely find your answers there. Better yet, put "speakers" or "idle" in the search function and you'll have plenty to read about your subjects.
cnjvh,
Sounds like either one of your shocks/struts have given out or one of the springs has been compressed for a long time one one side and is now permanently compressed. Get it to a shop that can look over all the components underneath to figure out what is causing the drop. Could be a broken sway bar also.
Old 20 Apr 2010, 10:19 am
In the case of something like a broken sway bar, would I notice something while driving? It seems to drive perfectly normally. Drives straight with no vibrations or anything (except a BARELY noticeable shudder while accelerating when I hit 20mph. After that its fine.)
Old 20 Apr 2010, 10:25 am
Never had a broken one so don't know if you'd notice, but most shops will inspect your car for free hoping to sell you something.
Old 20 Apr 2010, 11:08 am
Thanks :-) I'll get it checked then.
Old 21 Apr 2010, 11:32 am
I had a broken sway bar link and didn't notice. (on my '02)
Check your tire pressures....
Measure another day after having driven it and make sure it's consistent.
Old 21 Apr 2010, 12:31 pm
I actually did measure again yesterday and it was only 1/4 in off. Odd...
Trans. fluid level fluctuates!!!! 66CUDA Tech & Performance Forum 4 29 Jul 2009 12:57 pm
PH level of HOAT Coolant yaschief Tech & Performance Forum 2 13 Aug 2008 01:01 pm
Error Code Fuel Level Sender arizonasportsnstuff Tech & Performance Forum 2 26 Feb 2008 07:10 am
Gas level/gaugage LoboMXGT Interior Accessories Forum 3 28 Sep 2004 09:52 pm
Coolant Fluid Level Ed Lim Tech & Performance Forum 2 28 Sep 2003 07:38 pm
