Towing Milage?
Old 25 Apr 2010, 08:15 am
smallfrycruzr's Avatar
Question Towing Milage?
I tried a search but couldn't find the info I'm looking for, can someone help?
My question is about towing a PT. If the PT is towed with all 4 tires on the ground (5 speed), are the miles shown on the ODO, "engine" miles, or are they "wheel miles", if you get the drift of the question. Any help would be great.
Had one , sold it , want another one , D'oh!!
Old 02 May 2010, 12:43 am
Default Re: Towing Milage?
First off, never EVER tow a vehicle with the drive wheels on the ground, regardless of whether it's an auto or manual.
Secondly, the odometer will not be counting miles unless the ignition is on, and you're not likely to leave the key in with the ignition on for the duration of the trip.
That being said, if you leave the igntion on and the drive wheels are on the ground, yes the odometer will be counting and you will have "false miles" recorded that weren't actually driven.
-Chris
Old 02 May 2010, 08:00 am
Ok, I understand about the key on/off as far as regestering milage. But the comment about " never EVER tow a vehicle with the drive wheels on the ground, regardless of whether it's an auto or manual." has me a little confused. So, all cars being pulled by an RV with all tires on the ground are being damaged in some way?
I'm not up on towing anything, other than a semi trailer. How does towing a stick damage anything, does it hurt the tranny like it would on an auto tranny?
Not trying to be trouble, I'm just not informed with good information.
Old 04 May 2010, 02:03 am
Precisely. The fact remains that you're moving critical gears and parts by force rather than by driving. It's the same reason manufactures recommend against coasting in neutral with a stick. It causes a lot of premature wear on the drive train components.
And to answer your question about RVs, they're causing quite a bit of damage to their vehicles. We had one in our shop about a year ago. It was a brand new Dakota being pulled behind a big RV across the country. It wouldn't even drive under it's own power because the tranny and/or transfer cause had completely bound up inside. I don't remember if it needed a new transfer case or tranny, but it wasn't warrantable, and was a very expensive bill. They got a dolly from U-haul for the duration of their trip!
-Chris
Gas milage getting better! freetobejbp Tech & Performance Forum 1 04 Jan 2010 08:45 am
Gas milage again white General PT Cruiser Discussions 12 12 Jun 2009 06:26 pm
gas milage??? laneslate Tech & Performance Forum 3 03 Oct 2007 12:02 pm
gas milage john1342 General PT Cruiser Discussions 17 22 Jan 2004 12:27 am
Gas Milage Black04Turbo Tech & Performance Forum 43 01 Jan 2004 10:51 pm
