Issue with my 01 Limited PT - ABS and TRAC OFF light on
Old 20 May 2010, 09:03 pm
Default Issue with my 01 Limited PT - ABS and TRAC OFF light on
I was driving down the interstate and my car dinged and the ABS light and the TRAC OFF light came on. There is a grinding noise comming from the middle of the engine compartment heard thru the dash with the windows rolled up, if you roll the windows down the drivers side wheel sounds like something is grinding?
Other than these two lights, and the noise It drove just fine and I made it home, I searched the forums before I made this post, and couldn't find anything?
Anyone know what might be going on, or ever have the same problem?
My mechanic is out of town until next Thursday!
Thanks for the help guys!
Brian
Old 20 May 2010, 09:41 pm
Default Re: Issue with my 01 Limited PT - ABS and TRAC OFF light on
Also, I would like to add that I just went and read the codes, forgot that I could do that myself.
It goes straight to done. NO CODES?
Any help please!!!! I just need to know If I can safely drive about 8 miles a day to get to and from work until the mechanic can get to it in 6 days.
Thanks again guys and gals, you all rock!
Old 21 May 2010, 07:24 am
I checked around the web and the only thing I came up with is an owner that had the same symptom and it turned out to be bad sensor on one of the wheels which caused both lights (ABS and TRAC) to light up. Finding which sensor and replacing it cured the problem.
Your going to have to fine someone with a scanner to pinpoint your problem.
trac control & abs light staying on in dash bobs turbo pt General PT Cruiser Discussions 13 22 Apr 2017 08:44 am
Exterior (fog?) light issue judi Exterior Accessories Forum 13 31 Jan 2015 12:09 pm
Engine light issue Silverlemon General PT Cruiser Discussions 4 10 Feb 2009 06:52 pm
2003 Interior Light Issue CoryMartelca Tech & Performance Forum 2 02 Dec 2008 11:34 am
