Help with starting 2001 Pt Cruiser
Old 08 Jun 2010, 01:46 pm
Unhappy Help with starting 2001 Pt Cruiser
Well, I guess it is just one of those things.
I had my OBDII scanner attached, I went to put my foot on the clutch and hit the scanner, the plastic connector of the OBDII connector came off and the pins were exposed. Some of them touched each other with power on. Then the car would not start. I have since fixed the connector.
The car was working fine before this episode and is now not working. It does respond to the key radio signal for locking the car, everything seems to work but the car will not even crank. When I turn the key the radio goes off, but nothing else happens.
I disconnected the battery, waited 10 minutes and tried again. The same thing happens. I inspected fuses and found no bad ones.
I tried to get trouble codes but the car does not respond.
Any help would be appreciated.
Old 08 Jun 2010, 08:34 pm
Default Re: Help with starting 2001 Pt Cruiser
Did you check the fuses in the PDC (fuse box) in the engine compartment? Especially the IOD fuse.
Old 09 Jun 2010, 01:38 am
The IOD fuse would not cause the car not to start. Every single Chrysler product that comes in off the truck has the IOD fuse removed.
It almost sounds like when the wires touched, maybe you shorted out the computer.
-Chris
Old 09 Jun 2010, 05:06 pm
I blew a fuse, not the IOD fuse but the ETX fuse. I just started testing them all until I found one that blew. Replaced it and the car started again. I did not spot this fuse in any of the wiring diagrams that had to do with the starter so I did not test it before.
Everything is good now.
Thanks for the help.
Doc60
Old 09 Jun 2010, 05:19 pm
Do you mean the ETAX fuse No#15 20amp in the PDC of the engine compartment??
If that's the one, what a strange thing to make the cruiser into a non-starter because it's for the Electronic Automatic Transaxle.
Learn something new everyday.
Old 09 Jun 2010, 06:17 pm
Yes, that is the one. If you do not want a Pt Cruiser to go anywhere just pull it.
Old 09 Jun 2010, 06:22 pm
Well, I guessed the right fuse box, just the wrong fuse. Glad you got it running.
Old 09 Jun 2010, 07:18 pm
Fuse 15 also connects to the ignition switch, so it makes sense that the car wouldn't start. See the attached diagrams. In the second, it seems like power goes from the ignition switch, through fuse 15 and into the transmission controller relay.
-Chris
Old 09 Jun 2010, 08:07 pm
Well, who knows why they would run it that way but makes sense now why it wouldn't start. Thanks.
Old 10 Jun 2010, 05:58 am
Doc, thanks for posting the remedy, many do not.
2002 Pt cruiser starting issues ort102 Tech & Performance Forum 5 11 Jul 2011 07:28 pm
Dream Cruiser Starting Problem? cruise_carter Tech & Performance Forum 5 03 Apr 2010 06:45 pm
Problem Starting 02 PT Cruiser DavidH General PT Cruiser Discussions 6 20 Feb 2009 06:13 pm
Pt Cruiser Not Starting teknoron Tech & Performance Forum 8 11 Sep 2008 02:04 pm
2001 Starting question Circuitlaif Tech & Performance Forum 16 29 Mar 2004 11:33 am
