Bought an 03 gt today but it comes with a few problems
Error code P0480 Cooling Fan Relay 1 Control Circuit However my fan works, it is on whenever i start the vehicle, i dont think it ever shuts off?, bought it and drove it 300 miles without overheating Left front turn signal doesnt work. rear works, bulb illuminates in the front casing but does not flash, left turn signal arrow on dash illuminates a solid left green arrow(doesnt show up until i turn the lights on though) and when activated (i hit the turn signal to turn left) solid arrow flashes very fast, with lights off the turn signal doesnt work still in the front only difference is there is not a bright green arrow staring at me -So pretty much im driving it home tonight with the dash all lit up and my lights on and a big green left arrow staring at me. Also, what bulb is rear license plate as mine appears to be out? I hope just "out" Fuel needle in "wrong" position. It works when full the needle pointing over and almost hitting the temperature display needle (2 o'clock) and when on Empty it is almost at where the needle should be when actually full.. its like its rotated too far clockwise. when car is off it drops to normal spot (i guess) all the way down past E Could just be fuses? but I have no idea where fuses are on it and no manual to guide me. Any help would be appreciated, I live in Gainesville, FL |
Ran like a champ though, car is very fast
Oh what does -49celsius on the maplight compass temperature thing mean. I figured out how to change the zone but do i need to put a new thermometer somewhere? in the tailpipe? |
update - In the daytime when I use my turn signals -without my lights- on the left front one actually flashes but it flashes very very very fast. but when i turn my lights on it turns into a solid green arrow and wont flash in the front at all...
what kind of coolant can i get from the walmart to put in it? just the regular stuff? i need to top it off its getting low, i imagine from the long drive back from south florida? |
Do they sell that at walmart? can i just add it to whats already there. i think its orangish color. dark orangeish but orange i do believe
Approved Vendor ZXGO5RU1 Antifreeze/Coolant It seems someone may have rigged your fan to stay on, because it shouldn't be on all the time unless the AC is on. It's also a two speed fan on the non turbo. It sounds like you have some other electrical issues. |
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
napa nearby with zerex for 8.97 a gallon how do i drain the coolant completely and fill with correct coolant. i do not want to mix since you said its not the right stuff i need this car to last a few years and how many gallons will i need for the 03 chrysler pt cruiser gt everything in the engine bay is so crammed together my previous car is a 92 saturn, very spacious engine bay that car has half a million miles and now its on its last leg just the past week i paid 500 dollars for ignition control modules and then the radiator got a crack in it and the ac broke and transmission started slipping... all in one week... thats why i decided to buy another vehicle. Hopefully this one will see that many miles it seems so young in mileage(60k) compared to the saturn...
matthew,
Your system takes 6.5 quarts of coolant. A 50/50 mix of water and HOAT coolant. It mat be a little bit more expensive but DO IT if you plan on keeping the PT around like your Saturn. The tag light is a number #168 The rear lights are number #3157-P27/7W The front park/turn signal lights are number #4157NAKX If any of the bulbs stay lit or flash fast, check the other end and replace the bulbs. They are cheap and easy to replace. Fuel needle. Check all the needles by holding in the trip button while turning on the ignition key (don't start the engine). This will test all the numbers and dials. in all the guages. The temperature sensor is in front of the radiator when you open the hood. It's a little 2 inch thick needle that's attached to the center piece. Get yourself an owners manual and it will tell you how to change the setting from Celsius to Fahrenheit. You need the owners manual anyway for a lot of different things and again, if you plan on keeping the car it will come in handy. In the TECH section, look for all the free information and downloads. I'm pretty sure you get the owners manual for free. Don't know what to say about your fan. If it's turning and the PT isn't overheating anytime, then just keep an eye on it.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 14 Jun 2010 at 05:04 pm. |
Here is service manual
Thank Candyman, you owe him a beer, this is from the tech section. http://webdev1.net/hosted/documents/...shopmanual.pdf Get the hoat coolant G-05 at NAPA, Valvoline.com > Products > Zerex > Antifreeze Zerex > Zerex G-05® Antifreeze / Coolant
89 Shadow ES 2.5 T2 +20's A555 86 TurboZ CS 2.2 T2 +20's A555 90 Datyona ES 2.5 T1 A523 90 Datyona Shelby VNT needs work 00 Durango SLT+ 5.9 4x4 02 Grand Cherokee 4.7 4x4 03 PT GT Black 5 sp Stg 1 06 PT GT Cool Vanilla 5 spd Conv 06 PT Base Marine Blue 40TE Conv |
| Strange Happening | bados | Turbo Performance | 13 | 03 Jun 2008 06:37 pm |
| Weird Noise | ptlovr | Tech & Performance Forum | 7 | 05 Jul 2006 07:14 am |
| What's happening Oct 20th - 22nd | CREWZIN | Southeast PT Forum | 12 | 13 Jun 2005 03:18 pm |
| Cruisermania II-somethings happening | THISLPT | General PT Cruiser Discussions | 3 | 25 Aug 2004 04:19 pm |
| This is just too weird | turbomangt | Turbo Wheels/Suspension/Handling | 3 | 02 May 2004 11:04 pm |
