empty coolant w/engine light?
Old 17 Jun 2010, 07:04 pm
JSH JSH is offline
Default empty coolant w/engine light?
my wife went to work this morning and the enginelight came on, she drove home afterwards still on. I check the gas cap first, the all hoses and belts, then all fluid levels, I noticed the coolant reservoir is empty (sunday when we changed the oil the power steering fluid was bone dry). I picked up some prestone "works w/all colors" coolant and poured it in (i put too much), drove the car around the block for about 5-10 min and the light stayed on the whole time. will it go off on it's own? do I really have to take it to a mechanic to figure out whats wrong? how can you check for a code w/out paying the absorbatent price they ask @ the shop?
Old 02 Oct 2010, 06:34 am
Default Re: empty coolant w/engine light?
To check the codes stored in the computer, use this link:
How to retrieve fault codes.
To clear the codes, take the negative battery cable off for about 5 minutes.
empty fuel tank, engine runs bad afterwards autoenting Tech & Performance Forum 17 03 Sep 2010 04:36 pm
Special engine coolant fluid mstyler05 Tech & Performance Forum 8 19 Jun 2010 12:12 pm
engine coolant reservoir empty? PTC06Peet General PT Cruiser Discussions 19 17 Jun 2010 07:58 pm
PT High Temp.Coolant Light ohwez General PT Cruiser Discussions 2 08 Jul 2009 11:43 pm
empty fog light area Dilly General PT Cruiser Discussions 4 29 Jun 2004 01:29 am
