Air conditioner leaking into interior
Old 22 Jun 2010, 03:31 pm
Default Air conditioner leaking into interior
My air conditioner drain hose has started leaking into the inside of the car. Can anyone tell me where to located the drain hose? I don't know if it's called drain hose but the one that usually releases water to the ground.
2002 PT Cruiser Limited
Old 23 Jun 2010, 03:01 am
Default Re: Air conditioner leaking into interior
The drain tube is on the right side of the dash panel (firewall) under the hood. You'll see an elbow shaped tube pointing to the ground coming from the dash through the firewall. Squeeze the clamp to release it and remove the tube.
-Chris
Old 23 Jun 2010, 06:26 am
Thanks, you rock.
06 pt (A/C) leaking lots of water from the firewall at the ac inlet to interior steveohb Tech & Performance Forum 7 14 Jul 2009 08:00 am
Air conditioner probs. ccinder General PT Cruiser Discussions 2 18 Jun 2008 09:35 pm
Smelly Air Conditioner! auntwendy9 Tech & Performance Forum 3 24 May 2008 08:02 am
Air Conditioner Out of Whack ptkrwzr General PT Cruiser Discussions 3 14 Feb 2008 09:02 pm
Smelly air-conditioner 1lowufo General PT Cruiser Discussions 3 19 Jul 2004 09:42 am
