Why I Run Synthetic Oil
Old 01 Jul 2010, 07:55 pm
VNT's Avatar
VNT VNT is offline
Default Why I Run Synthetic Oil
Doing a Little Maintenance, changing the radiator slight leak this winter at the seam, rad and heater hoses, turbo coolant hoses, oil cooler hoses etc, a few sensors while I have everything apart and I'll toss in a new starter since they are cheap, my pal got me a mopar one for 80$.
Car has a tad over 100K. Since I had to yank the intake I thought I would yank the valve cover too. Going to paint them both in wrinkle paint black.
ANyhow the car had 17K when I bought it in 2004 and had 3K miles dino changes bulk Mopar 5w-30 garbage oil according to the receipts in the guys book in the glove box.
Since then I have used Amsoil 5w-30 and Amsoil 5w-30 Diesel Oil for the winter season for about 8-10 K mile intervals from Nov to April, and whatever cheap Group III Fake Synthetic mostly Penz Platinum,Mobil 1, QS Horsepower or Advance 5w-30 or 10W-30 from my stash. Use these with 2 changes April to July and July to Nov with maybe 5-6K mile intervals. I uses Amsoil Super Duty Filters and when they swithed to the Donaldson media on the EAo series I use those. Air filters have been Puralator or Fram.
Also I change the PCV valve every other year about 25 K miles.
Was pleased since I expected it to be spotless with the Amsoil. Note their was no varnish and anything you see in the picture with the gold tinge is actually a film of oil. You can see the paint markings on the valve springs.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 01 Jul 2010, 09:25 pm
Default Re: Why I Run Synthetic Oil
I'm a believer in Synthetic also. Had a new oil pump put in my Vette at 150,000. Don't do that kind of work myself but mechanic even commented on the spotlessness of the bottom end of the engine and little wear and tear after those miles. I've used Mobil 1 since new back in 1987.
Old 02 Jul 2010, 07:55 am
jbcrzn's Avatar
Hey guys! This may be a silly question, but do you both recommend running synthetic oil from the outset or changing at a certainly mileage marker?
jbcrzn
2012 Dodge Charger
2006 Nissan Xterra
Former: 1986 Dodge Daytona, 1988 Jeep Cherokee, 1997 Pontiac Sunfire, 2002 Jeep Wrangler, 1995 Ford Taurus Wagon, 2008 Chrysler PT Cruiser
Old 02 Jul 2010, 09:26 am
I had a '92 Dodge Spirit that I bought new. Changed to synthetic at a couple hundred miles.
At about 150,000 miles it ran like crap - it had sucked a valve guide.
Mechanic had the head sitting on a bench, and the valve and cams were all bright and shiny - I asked what he used to clean it up, thinking he has soaked it in Gunk or something - he said "that's they way it was".
Synthetic oil is worth the extra few $.
I use Mobil 1.
Old 02 Jul 2010, 09:59 am
A lot of new cars come with Synthetic already in them from the start. I was always told that a high mileage (100K+) car shouldn't change to synthetic if they hadn't already had it because synthetic will find the smallest of cracks/leaks and turn it into a leak you never had. Don't know if that's true or not but I wouldn't worry about that and if your going to change, do it now and don't forget to get all the old oil out and change the filter.
Supposedly though, if you ever needed a quart of synthetic oil in a pinch and didn't have any, adding a quart of Dyno wouldn't hurt.
Old 02 Jul 2010, 11:26 am
jbcrzn's Avatar
Thanks, Crewzin.
jbcrzn
2012 Dodge Charger
2006 Nissan Xterra
Old 02 Jul 2010, 12:05 pm
I started synthetic on our 08 with 41k on it,have not seen even a small drip,but was concered about that.Now im coming up on 3000 miles on it and seems a waste not to let it go to 4-5k range,but might just change it at the normal 3k,can change it under 30 bucks with a wix filter.
Old 02 Jul 2010, 12:14 pm
I use synthetic since its first oil change and change it around the 5,000 mile mark.
Old 02 Jul 2010, 06:26 pm
What if the car does not get driven much? Is it better to use the synthetic oil if the car will probably get less than 1000 miles a year and be stored in the winter?
Old 02 Jul 2010, 06:47 pm
I don't see any advantage to going synthetic for very low mileage cars but from what I've read yo still want to change your oil about once a year.
Synthetic Oil kprawdzik Tech & Performance Forum 24 20 Dec 2010 06:39 am
SYNTHETIC OIL? mopar1cjh General Turbo Discussions 6 06 Apr 2009 10:48 pm
Synthetic wax coopj40 The Detail Shop 14 20 Dec 2007 01:07 pm
Synthetic oil deederz Tech & Performance Forum 24 05 Feb 2005 03:46 am
SYNTHETIC OIL AJ General Turbo Discussions 17 26 Sep 2003 05:57 pm
