Completely dead battery after parking for 1 month. problem?
Old 04 Jul 2010, 03:53 pm
Default Completely dead battery after parking for 1 month. problem?
hi all,
i've not been around my pt cruiser for about 5 weeks. before i left, my car was running well and never failed; when i returned, a car is dead (even a remote wouldn't work). i would like to know if this is normal, considering noone drove this car for over a month. or if all i got to do is a jump start. i couldn't tell when a battery was installed and when i should replace it. btw, my car is a 2005 manual with about 65k mi.
let me know your 2 cents
thanks!
Old 04 Jul 2010, 04:20 pm
YoungCruiserrr's Avatar
Send a message via AIM to YoungCruiserrr
Default Re: Completely dead battery after parking for 1 month. problem?
I parked my car all winter in Pa, so like early/mid november, till about march/april and it had no problems.. every few nice days I would take it out for a drive and let it run, but never had a problem of dead battery
2005 Brilliant Black
PT Cruiser Touring Edition
34,000 Miles.
Old 04 Jul 2010, 04:22 pm
i did not start my car at all for 5 weeks. what should i be looking at for any (bigger) problem than simply a jump start?
Old 04 Jul 2010, 04:29 pm
I'm not the one to ask, but I had a friend recently had lose wires and it was as simple as that.. Someone else with more input will come along, I'm not the one to ask
34,000 Miles.
Old 04 Jul 2010, 06:12 pm
It may just take a jump start, but if you have no idea when or if the battery was changed, I'd suggest you take it to a auto place to have it checked. There normally is no charge as they hope you will buy a battery (if needed) from them.
Old 04 Jul 2010, 06:45 pm
Today's cars (everyones) have so many computer modules that draw power, it is common for a battery to run down.
There is a fuse that should be pulled called an ignition off draw fuse when the vehicle sits for some time. If it is not in the owner's manual, any dealer can show you which fuse. It has a little clip on it to make it easy pull out.
If your battery went totally dead, I would have it load tested. I would not trust it next winter.
Old 05 Jul 2010, 01:11 am
You're problem is most likely that you let the car sit so long the electrical systems simply ran the battery down. I'd skip the jump start and just get a new battery. Chances are that letting the battery get discharged to that level that it will not properly hold a charge anymore.
When you store the car, remove the battery. Simply pulling the IOD (ignition-off draw) fuse is not enough. The IOD fuse inhibits electrical draw on the battery when the ignition is off, however it doesn't eliminate all electrical draw. There are still traces of electrical draw even with the IOD fuse removed.
Either remove the battery and charge it periodically, or start the vehicle every week or so to keep the battery fully charged.
-Chris
Old 05 Jul 2010, 09:44 am
Or simply use a product like a "battery tender" to keep the battery up to perfect charge for long periods of time. If you've never used one, they work great!
Jerry
Old 05 Jul 2010, 12:58 pm
hi all,
last night, i jump-started my pt cruise: it took approx. 10 min of running my friend's car before my car started. i drove for 20-30 min then parked. this morninng as i tried to drive it to work, the battery's (seemingly) dead again with no light, no start, and noda. i do feel like i should replace a battery now or something. what's a battery tender??
thanks
Old 05 Jul 2010, 01:34 pm
Replace the battery. A tender is a trickle charger, good for keeping the battery charged. No good to charge a dead battery.
Dead Battery???? I think not... cruisergeo Tech & Performance Forum 12 02 Sep 2016 04:32 pm
Dead Battery? dveldt Tech & Performance Forum 10 28 May 2010 04:59 pm
dead battery overnight strokedmaro Tech & Performance Forum 2 11 Sep 2009 09:15 pm
Door lock problem after dead battery/jump start Mal Interior Accessories Forum 1 11 Jun 2009 09:32 pm
Dead battery at 33K miles sawdust123 General Turbo Discussions 14 16 Dec 2005 05:56 pm
