washer does not work
Old 06 Jul 2010, 01:33 pm
Default washer does not work
Hi Guys - I am new to this forum, so please bear with me while I try to explain this rather interesting problem. I just picked up a 2008 PT Cruiser - 34K - and all seems well - except for the deer I hit last week, but that's another story..The windshield washer for the front window doesn't work. When I pull the lever, no fluid comes out and the wipers don't turn on. The wipers work fine otherwise, they just won't turn on when I hit the washer. I checked the rear wiper/washer and it is functioning correctly. In my opinion, the pump seems to be OK and the switch in the column is bad, but before I go throwing a lot of $ at it, I want to make sure I am not overlooking something easy to fix. Can anyone help? Thanks
Old 06 Jul 2010, 09:35 pm
Default Re: washer does not work
Open the hood and look at the tube that delivers the windshield washer fluid to the nozzles on the hood.....my "tube" came "loose"??, or broke apart?? from the nozzle....so I super glued it to the nozzle and all is good...going on 2 months now...hope this helps for a cheap fix...
2006 PT GT Vert - 2.4l Turbo, Black/Gray leather, MSD ignition wires, Royal Purple 5w-30 synth oil and filter, Sylvania Silverstar Headlight upgrade, TOYO Extensa High Performance tires
Other rides:
2008 Honda Odyssey Touring Edition, NAV/DVD
2010 Toyota FJ Cruiser 4x4 Trail Teams Edition
Old 07 Jul 2010, 05:58 am
My daughter's PT decided to stop squirting - I took off the blanket under the hood, and that's where the fluid was - the bottom of the squirters had disintegrated. I put in LED squirters (without hooking up the LEDs) and all is well.
The clips holding the blanket on are a PITA - I used needlenose pliers and a flat screwdriver, and with turning them, got them out.
Old 07 Jul 2010, 07:44 am
Thanks, Guys. I will check it today after work!
Old 07 Jul 2010, 07:46 am
I don't think that that would explain why the wipers do not turn on, though...
Old 08 Jul 2010, 04:41 am
Not the squirters or any of the tubing....gonna have to try the switch, I guess
Old 10 Jul 2010, 11:06 am
The car is still under warranty. Why not just have it fixed rather than putting your own time and money into it?
-Chris
Old 11 Jul 2010, 12:45 am
chris15's Avatar
I had the same issue with my PT. Front ones wouldn't work, but the back ones were fine, so I took the tank out with the pump intact, and checked the pump..
In layman's terms, the pump uses a 'flapper' valve that has two positions. In position 1, it blocks off the tube leading to the rear wiper, and in position 2, it blocks off the tupe leading to the front wipers.
What had happened was, the 'actuator' on the flapper valve had quit working, and wouldn't move at all-- it was stuck on the rear. So, being that I didn't really use my rear wiper all that much (and I've since recently 'shaved' my rear wiper anyway), I manually popped the flapper valve over so that the front wipers would work.
Of course, you can easily fix this by obtaining a new pump.
Or, if you are still under warranty-- have the dealer fix it, but your issue appears to be identical to mine, and that was the problem. Hope this helps.
EDIT: Keep in mind that this was for a 2001, and I am not positive if the design of the pump changed between then and now.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 11 Jul 2010, 06:43 am
Idropped the car off at the dealership on Friday to have the body work done for the deer strike. They will have it for about a week, during that time they are gonna take a look at the washer/wiper issue. I asked them if it was a warranty issue, and they informed me that because I bought the car used, the warranty was 90 days or 3750 miles, whichever came first, I went over the mileage by about 800 miles, but we will see if they still can help me out. Thanks for the help, and I will keep you posted on my progress.
Old 11 Jul 2010, 11:35 am
How the hell did they come up with 3,750 miles? Couldn't they make it 5,000 miles?
LED washer longevity quicksilverdon Exterior Accessories Forum 6 13 Jan 2005 08:37 am
Pressure washer Mr.Barton The Detail Shop 7 27 Oct 2004 09:19 pm
Washer Nozzles SRG General PT Cruiser Discussions 2 02 May 2004 11:25 am
Washer LEDs quicksilverdon Exterior Accessories Forum 7 28 Feb 2004 12:23 pm
Washer fluid ssbandit19 General PT Cruiser Discussions 1 27 Sep 2002 03:20 am
