05 touring: Backfire/thump sound after start
Old 06 Jul 2010, 03:05 pm
Default 05 touring: Backfire/thump sound after start
Hi all,
Just recently my 05 Touring has started making a pop/thump sound after starting the engine (cold). Has happened as soon as 10 seconds or as long as 2 minutes or so after starting. Almost sounds like a backfire through a silencer. From the drivers side it sure sounds like its coming from the passenger side engine compartment but could be wrong.
Seems to only happen once, car seems normal after that.
Old 06 Jul 2010, 03:07 pm
Default Re: 05 touring: Backfire/thump sound after start
Am currently dealing with the AC overheat/bad idle/white smoke issue...could they be related?
Old 06 Jul 2010, 03:33 pm
Yes it could be. When the compressor heats up and needs to discharge excess R134a, it pops a valve open and releases pressure (R134a - white smoke). You have to find out what's causing the compressor to build up pressure. Usually it's becuase the fan isn't doing the correct job of keeping everything cool.
Old 06 Jul 2010, 04:34 pm
Ok, thank you very much. I will get the AC dealt with first and then go from there.
car won't start, goofy sound jdmickies Tech & Performance Forum 6 21 Feb 2010 08:50 pm
2006 Touring Ed. wont start.... help!!!! marvinev General PT Cruiser Discussions 4 18 Feb 2010 06:42 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
p.t thump in front end guitarrich Wheels, Tires, Suspension 2 03 Jul 2009 07:11 pm
Clank sound on Start up DaShado General PT Cruiser Discussions 2 01 Jul 2007 11:11 pm
