No Car Start, No Cry
Old 07 Jul 2010, 09:38 am
fezzersc's Avatar
Default No Car Start, No Cry
Ok, We were going to go get my wife's New to her PT registered and plated, and when she went to start it.
Click.
All lights are working. Not trying to turn over.
Just CLICK.
Tried jumping it, maybe didn't wait long enough. Will try again tonight and let you guys know.
Thinking Starter.
Any ideas?
Old 07 Jul 2010, 09:48 am
fezzersc's Avatar
Default Re: No Car Start, No Cry
Ok, I read a couple similar posts. Sounds like the battery will be the problem. going to try to jump it again and then go to auto zone and have them check the charge/ alt/starter/whatev.
Old 07 Jul 2010, 02:58 pm
I just had to change my battery and went through the procedure for jumping from a good fresh source. First couple of times NOTHING. Started messing around and just hit the "sweet" spot and it started right up. Just sometimes it's just not making that perfect connection on the positive or negative spot. You shouldn't have to wait till later, the fresh battery should give it all you need to start the dead one if the connections are perfect.
Old 07 Jul 2010, 07:02 pm
fezzersc's Avatar
I found the trick for finding the codes on the odometer P1684.
Old 07 Jul 2010, 07:19 pm
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles. "Done" indicates that no DTC's are present and the procedure is complete.
Back to your original thought to have the battery and charging system fully checked.
Old 07 Jul 2010, 08:09 pm
fezzersc's Avatar
The answer is Starter. We're replacing it this weekend. It's starting now. I just got show my wife the tapping trick.
And yes, my Uncle cleared the power steering sensor code saturday, so that makes sense. Thanks/
Old 10 Jul 2010, 11:18 am
To elaborate on P1684, it doesn't simply mean the memory was cleared. The PCM has battery powered RAM, so when you disconnect the battery, it clears the RAM, setting this code.
It's caused by removing/replacing the battery, disconnecting the PCM, etc.
It has nothing to do with ignition cycles or clearing other codes.
-Chris
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
car won't start sonny562 Tech & Performance Forum 7 16 Aug 2004 08:14 am
Where to start??? ptdreamer Turbo Performance 9 30 Jul 2004 11:12 am
Where to start??? ptdreamer Tech & Performance Forum 3 29 Jul 2004 02:06 am
