Please help
Old 07 Jul 2010, 05:17 pm
Send a message via MSN to saldagus
Unhappy Please help
Well last Friday I thoght I had a Harley idlng behind me. Turns out it was me.
Car idles real rough and lumpy, when I "blip" the throttle the engine raises rpms normally, however on the way down they drop to below 500 rpms, the engine stumbles, wants to die but recovers into it's lumpy idle.
Car idles fine when I first start it in the morning, but as soon as it gets slightly warm it starts missing.
I've changed plugs, wires, coil pack, intake manifold gaskets, checked for vacuum leaks, and cleaned the IAC. The kicker is no check engine light and no codes stored in memory.
Any suggestions besides attaching it to the end of a long chain and usig it as a boat anchor?
Old 07 Jul 2010, 06:18 pm
ROCKETMAN8060's Avatar
Default Re: Please help
What type of PT you have and how many miles it has?
ROCKETMAN8060
Old 07 Jul 2010, 06:39 pm
It's an 01 na. With 225000 kms. Approx 140000 miles
rad fan has also been replaced
Old 07 Jul 2010, 07:15 pm
Ya gotta ask the other things with that kind of mileage. Timing belt, water pump changed? Besides cleaning the IAC which control idle, did you check to make sure the spring is working correctly? Did you take a look inside the throttle body, it could probably use a good seafoam or major cleaning.
Old 07 Jul 2010, 07:41 pm
Timing belt and water pump were both done for the second time last year. Just did a seafoam treatment. What should I be looking for in the IAC?
Old 07 Jul 2010, 08:03 pm
Dino's Avatar
Lower intake gasket??? Spray some starter fluid around it and see if it idles better.
Old 07 Jul 2010, 09:19 pm
Did that with wd40. Also replaced the seals
Old 08 Jul 2010, 07:51 am
Dino's Avatar
Sorry didn't see that, wow you do have a weird one. Fuel issue??
Old 08 Jul 2010, 08:08 am
I don't see anything about injectors - I've read of a couple intances where an injector was replaced and cured rough idle - try a lot of injector cleaner first.
Perhaps a compression test?
