new member please help
Old 08 Jul 2010, 08:21 am
Default new member please help
iam working on a 05 pt crusier 2.4 i came into the middle of this job of replacing a head and timinig belt so i received the car disassembled i put everything together and now when cranking the car iam getting no fire to the plugs, nor any signal to the injectors. i have a snap on solus scanner and its saying the cam and crank sensors are not sync'ed. ive checked the timing 4 times and iam pretty positive its perfect. ive read of a asd relay that could be preventing it from starting but am not positive. does anyone know if the cam gears are different b/c iam not sure if they got swapped around in the process being i wasnt the one taking it apart. ive just about ran out of suggestions and iam in dire need of some professional help. ive changed the cam and crank sensors also just to check. the thing that has me stumped is for one second i got signal to the injectors and my scanner showed that the sensors were sync'd but nothing after that please any help would be appreciated and would be willing to buy anyone with some help a round of beers if they are local enough
thanks in advance
brandon
Old 08 Jul 2010, 08:25 am
Default Re: new member please help
if more info is needed please lemme know
Old 08 Jul 2010, 10:29 am
the codes iam pulling are PO335 PO340 PO129 if that helps
Old 08 Jul 2010, 11:55 am
found the problem seems the coil pack plug and cam sensor plug are the same and had them crossed i feel so dumb
Old 08 Jul 2010, 12:36 pm
Glad you found your answer. That would have been almost impossible for any of us to figure out that you crossed plugs.
Old 08 Jul 2010, 04:51 pm
Thankfully a friend at the dodge had done the same thing
New Member CREWZIN General PT Cruiser Discussions 7 05 Jan 2009 11:41 pm
New Member - Hi WV05Cruiser General PT Cruiser Discussions 19 24 Sep 2008 09:35 am
new member smottman General PT Cruiser Discussions 15 11 Apr 2007 07:16 pm
New member Mopar GT General Turbo Discussions 12 11 Jul 2003 06:37 pm
New GT Member Turbo Red General PT Cruiser Discussions 5 18 Mar 2003 07:21 pm
