2006 PT Cruiser - How to disconnect the horn so can use the car!
Old 09 Jul 2010, 01:44 pm
Exclamation 2006 PT Cruiser - How to disconnect the horn so can use the car!
Hi there,
Well, our one & only remote got put through the wash, so I had to dry it out the best I could ...
As I was doing that, the car horn started going off, every minute or so! I finally disconnected the battery, so as to shut the blaring horn off .... Now I need to know how to find and disconnect the horn relay, so that I can drive it into town to get it checked out. As I am a senior, I don't think I have the energy or know-how to start taking the whole car apart, just to get this HORN PROBLEM solved!
Much thanks for any suggestions, as I need to be able to drive my beloved cruiser, sans embarrassing horn blaring the whole way to town!!!
Pete
Old 09 Jul 2010, 01:57 pm
Default Re: 2006 PT Cruiser - How to disconnect the horn so can use the car!
Pete,
Would really like to help you out as I see most posts first but Darn Chrysler changed things around so much for the 2006+ models that they don't label the horn/relay anymore. Real easy on the 00-05 PT's. Nothing on the fuse/relay chart for your model shows where the horn fuse and relay is located.
Worst case scenario is to get under the inner fender of the passenger side because that's where the horn is actually located. The horn connection of course is in the middle of the steering wheel and you don't really want to mess around with that.
Hopefully one of the Chrysler mechanics or someone that knows more about the horn relay or fuse will come along soon and help you out.
Old 09 Jul 2010, 04:22 pm
Angry Re: 2006 PT Cruiser - How to disconnect the horn so can use the car!
Thanks for the reply ... Now that's pretty interesting, as I've been having a good look around and have yet to locate that horn relay! I've called for a tow, as that will keep the neighbours happy and will get Chrysler dealer in town take care of it .... Hopefully, we'll be able to get this thing disconnected A$AP!
Thanks again for the info .... HONK, HONK Pete
Old 10 Jul 2010, 10:49 am
The horn fuse is #23 and the relay goes between terminals 62 and 66 in the TIPM.
-Chris
Old 10 Jul 2010, 10:59 am
Thanks Chris. We sure can't tell anything by looking at the owners manual for fuse use and location.
Old 11 Jul 2010, 12:20 am
It's like a whole different language, huh?
-Chris
Old 29 Mar 2011, 08:51 am
Does fuse #23 work any other components? And how do you get to the relay between terminals 62 and 66?
Old 29 Mar 2011, 10:41 am
I looked at my owners manual yesterday when radar detector didn't work, under fuse it shows the location of the TIPM under hood ... no chart, have to go underhood and pull the cover and look at that chart.
The 01 is different, but also has fuses and relay inside and underhood, 06 has them all underhood. Well ... unless added items. The rader needed a new 2A tube type fuse inside the lighter pluggin.
Glad you got the info ... was gonna go pull mine for ya.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 29 Mar 2011, 11:28 am
Pete, where abouts are you located? Just curious if you're close enough for me to check it out.
Old 17 Mar 2013, 02:12 pm
OK ... I removed the fuse in cavity 23 - but the horn still honks.
Now what?
I need to disable the horn.
Tags
disconnecting horn, horn, horn relay, pt cruiser 2006
Horn not working, Fuses not blown... 2008 pt cruiser LX psyclon99 Sound and Security Forum 14 13 Jul 2016 06:27 pm
Battery disconnect = MPG reset. Howzit work? dolemite General PT Cruiser Discussions 2 06 Jun 2013 10:24 am
How to Disconnect Factory Alarm 02 Pt TPB Sound and Security Forum 4 04 Mar 2008 12:47 pm
2006 Horn Fixed Hooligan Interior Accessories Forum 4 17 Feb 2007 08:54 pm
Negative battery terminal disconnect necessary? KingKole02 Sound and Security Forum 11 16 Feb 2004 03:12 pm
