Shaved door handles? Remote problem
Old 09 Jul 2010, 09:58 pm
marvinsc's Avatar
Default Shaved door handles? Remote problem
The 01 PT we bought last weekend has had the door handles shaved, the wood kit covers where the handles would be. It has an aftermarket 2 button remote that rolls down the driver side window to get access to the car. I changed the battery in the remote and it has lost its program, the light comes on but nothing happens. Anyone have any idea how to re program one of these things? There is no brand on the remote, only a FCC id number.
Old 10 Jul 2010, 05:54 am
chigger_ns's Avatar
Default Re: Shaved door handles? Remote problem
Your going to have to find that brand name... check the main mdual that it speaks to.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 10 Jul 2010, 07:38 am
marvinsc's Avatar
This is weird. I backed the cruiser into the driveway and popped the hood to have a look around for that receiver. Didn't see anything under the hood so I got back in and hit the remote and the window rolled down! Tested it several more times and it is working again. Not sure what to make of this but I still would like to get a spare remote.
Old 10 Jul 2010, 07:41 am
Apparently something was loose or not making contact and opening or closing the hood got it working again. It will be hard to trace that kind of problem down but can be done with time.
Old 10 Jul 2010, 10:00 am
You gain access via the window? So, is there a manual emergency entry installed somewhere on the car in case the remote doesn't work.
Old 10 Jul 2010, 10:42 am
marvinsc's Avatar
Correct
Old 10 Jul 2010, 11:04 pm
chigger_ns's Avatar
Check under the steering wheel, That panel pulls down on a hinge. My car starter module is there.
Old 11 Jul 2010, 02:33 am
Candyman's Avatar
Smile Re: Shaved door handles? Remote problem
Hey their Marv,
Goo to hear you at least resolved your problem for the moment. For future reference just to be on the safe side of things, I would really recommend trying to trace out the line till you locate the receiver and get the brand name just in case you need it again at some point in the future.
Like chigger said, it may likely be hidden in the plastic panel right under the Steering Column.
The reason for the Importance of having the Manufacturer Information is, most Manufacturers program their Remote's via specific rhythmic coding, and most everyone for proprietary reasons likes to have their own unique Coding process, so should your Remote stop working, you won't be left out in the cold trying to figure out how to get your remote to let you back in your ride.
It could be as simple as holding the button down on your remote for5 seconds, then your power window switch up, and wait for an audible beep, or flash from the remote confirming the inf, or it could be a big time long, complicated mess. To me, I'd rather be safe than sorry, so like i was sayin, I would go ahead and trace it out, and have the info handy just in case.
Also, just out of curiosity, most of the time, it is an important aspect of doing shaved doors that the Installer put in a secondary way to get in just in case the battery dies on you. Usually it will be some type of a toggle switch set up hidden somewhere out of the way inside a wheel well, or behind a section of grill, or somewhere.hidden from view, but their if you ever should need it.
Ya never know, it just might pop up one of these days. Just gotta keep an eye out for it.
Check out my Custom PT Club Website: http://westvalleyforum.proboards.com/index.cgi
And my ever growing PT Photo Archives: http://s458.photobucket.com/albums/q...uiserArchives/
Please Like my Hot Rod Restoration and Detail Shop on Facebook.
https://www.facebook.com/BlueDiamondDetailing
Old 11 Jul 2010, 08:09 am
marvinsc's Avatar
Did indeed find the black box tucked up under the steering wheel but it has no brand information on it. It does have programming information printed on the back cover. I will take it to one of our local electronics geeks to see what the odds of getting another remote programmed are.
Old 11 Jul 2010, 09:51 am
Dino's Avatar
No door handles would wig me out, even if it looked really nice like it does on your PT.
Door Handles tbtk1 Tech & Performance Forum 10 14 Apr 2012 12:33 am
Shaved door handles DBROWN03 Exterior Accessories Forum 16 15 Jun 2005 01:54 am
Door Handles bigtommy83 Exterior & Interior Styling 0 25 Jun 2004 09:20 am
Shaved door handles gonzomania General PT Cruiser Discussions 11 14 Mar 2004 03:46 pm
shaved door handles ibynot Exterior Accessories Forum 4 15 Feb 2003 02:21 pm
