2000 PT won't turn over
Old 12 Jul 2010, 05:55 am
Default 2000 PT won't turn over
Hi My 2000 PT not been used for a couple of months. I re Charged the Battery but it will not start. The usual lights come on the dash and a relay in the box click when I try to start it (foot on clutch) but the starter does not turn. If I remove the solanoid connector on the starter motor and use a Jumper the the battery she turns over.
Can someone give me an idea where to start looking.
Cheers
Mick
Old 12 Jul 2010, 07:06 am
Default Re: 2000 PT won't turn over
Welcome to the Forum. If this is an original battery, it is time to replace the battery.
Old 12 Jul 2010, 07:24 am
you have to replace the battery and your problem is solved, the pcm or the car computer will test the battery and will not allow the engine to start if it isnt in good condition !!
happened to me too and jump start didnt work !! once battery replaced everything is fine since
Old 12 Jul 2010, 07:27 am
Hi
Thanks for your fast responce. I have fitted a New Battery today. If I switch on the Ignition the jump the solanoid terminal to the battery + she bursts into life but will not start off the key. Checked the relay it has continuity when switched. Now suspect the Clutch Switch. Is there anyway of by passing it. ? Silly Idea anyway, I don't know how I have managed without one for so long !!!!!.
Mick
Weird rumbling noise in dashboard when I turn over the engine/ turn off the engine... thinkinboutit Tech & Performance Forum 5 22 Jan 2014 08:23 pm
dome light doens't turn off till i turn on the car... realized Interior Accessories Forum 3 15 Jul 2009 06:44 pm
Turn Will not turn PT 2002 WanttoPimpthePT Tech & Performance Forum 19 09 Jul 2009 12:43 am
350 + HP for around $2000.00 coopj40 Turbo Performance 7 02 Jul 2006 08:01 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
